Pioneer AVIC-D3
Old 06-11-2007, 01:46 PM
nybull05's Avatar
Originally Posted by PolishPauL
Thanks for all your help. I have one more question for you. Was there a vss wire that you hooked up? I really wanna get that hooked up and im using the stock amp
Not sure what you mean by vss. Is that the speed sensor. If so yes there was. But i didnt do my install, i had best buy do mine. Thats were i got it. And the stock amp i had to bypass because i didnt use that special harness. So if you want to keep it then get that harness. I didnt want to spend 150 on it if i am doing custom audio work.
Old 06-11-2007, 02:59 PM
PolishPauL's Avatar
So how much did best buy charge you and did they do a good job? I dont really trust best buy.
Old 06-11-2007, 06:02 PM
nybull05's Avatar
they did an alright job, they didnt have the dash kit so they had to make one. They charged me like 300. I wish i went else where but that is where i bought it and just gave it to them.
Old 06-11-2007, 09:46 PM
Broke EF's Avatar
Ok I have a 07 LS with the base stereo, I have exactly 0 options. What harness do I need to get this headunit in my car, and have everything working with 0 problems? FYI my DIC is in the speedo.
Sean
Old 06-11-2007, 09:51 PM
nybull05's Avatar
Sean
well dont quote me on it, but i would say just the basic harnes.
Old 06-12-2007, 12:12 AM
effex80's Avatar
Okay, I have a 2006 SS/SCC with the premium sound package. All the pioneer **** with stock sub and crap.
I want to buy te AVIC - D3 Unit...soon.
I dont want to half ass the job.
What is everything i need to retain all my chimes and keep my existing XM?
Old 06-12-2007, 12:38 AM
nybull05's Avatar
one i can tell you is that no matter what you do you will not lose the door chime it is not part of the radio. But the xm i'm not sure about cause i got rid of xm and went to sirus. But i can guess is you might need that special harnes. You can find it on crutchfield.
Old 06-12-2007, 06:19 AM
Broke EF's Avatar
I just quoted you on it
Sean
Old 06-12-2007, 01:03 PM
gillz's Avatar
That is bad ass looking... definately what should have came stock.
Do these HU's have any video inputs to hook a laptop or ps2 up?
Old 06-12-2007, 10:14 PM
PolishPauL's Avatar
http://cgi.ebay.com/PAC-SWI-PS-Steer...QQcmdZViewItem
Do you really need that to make the steering wheel controls work or is a new harness good enough?
Old 06-13-2007, 11:16 AM
  #36
nybull05's Avatar
i am not sure if you need that with that special harnes. But if you go with the cheap harnes yes you need that. I need to get that for mine.
Old 06-14-2007, 11:58 PM
  #37
PolishPauL's Avatar
http://www.techronics.com/index.cfm?...roduct_id=2831
So thats not the one right? We need the regular one not the class II?
Also does anyone know the model number for the dash kit or the cheapest place to buy it
Thanks in advance. I wanna order both ASAP. I ordered the head unit and ipod cable yesterday.
Old 06-15-2007, 09:30 AM
  #38
nybull05's Avatar
i found a install kit on pioneers website, but could not buy it. So i searched on ebay a found one. I bought that one, i just hope it is the right one. If not i lost $30.
The model number for the kit is ADTVA-133
Old 06-15-2007, 10:17 AM
  #39
PolishPauL's Avatar
I saw a lot of them for less then ten dollars plus shipping on audiooutfitters.com. There are a couple different models that look the same but there all made by metra. One says cobalt turbo so im guessin they meant supercharged. Il try to give em a call once i get home from work. I wanna order the harness from them too but its outta stock
Old 06-15-2007, 11:05 AM
  #40
musifreak190's Avatar
What settings do you keep you D3 on for music? EQ, Staging, HPF, SLA, Loudness?
Old 08-11-2007, 01:18 AM
  #41
Capthowdy3200's Avatar
on the GMOS-LAN-04 what wire is for the vss
Old 08-11-2007, 11:51 AM
  #42
PolishPauL's Avatar
Its blue and pink but if you have the older version of 1.0, it doesn't have the vss wire or any nav outputs.
Old 08-12-2007, 12:38 AM
  #43
i got the 1.1 ver.
Old 08-12-2007, 02:02 AM
  #44
lightsout's Avatar
I got my Avic D3 installed about a month ago. I have the metra harness and used the GMOS LAN so I could keep my retained power. I also got the pac steering wheel adapter installed so that I could use my steering wheel controls. Basically the HU is connected to the factory Pioneer AMP and Speakers. My Sub and tweeters all work fine.
Old 08-30-2007, 02:22 PM
  #45
Need4Speed0to60's Avatar
where an i get all that for mine, I want to install soon but i want everything to work too.
Old 08-31-2007, 01:00 AM
  #46
Kurupt Rican's Avatar
I got mine done in Circuit City and they were great. Same day installation they had all the harness xcept the one for the steering wheel but other than that everything works fine and looks slick like it came with the car.
Old 09-03-2007, 03:00 PM
  #47
lightsout's Avatar
Well I got mine done at a car stereo installation store where I live in Toronto Canada. I would suggest that you look around at different installation places including circuit city and tell them exactly what you want. If they say they can do all of that ask them for the name of the modules and adapters that they will use. Then you will know for sure if they can do it.
01-12-2016 12:01 AM
chefhhr
10-26-2015 10:36 PM
nathan112i
09-30-2015 07:12 PM
09-27-2015 08:53 PM
Quick Reply: Pioneer AVIC-D3
