Pioneer XM tuner install
I installed my xm tuner a while back, but never got around to putting these pics up. I hope this is helpful for you guys, just to show you can retain the factory mount and antenna from your stock xm tuner setup.
heres the two units (stock xm tuner and pioneer xm tuner)
Heres where i dremaled the antenna plug so the stock antenna would plug right into the pioneer unit
heres a quick picture of what i did to make the stock antenna plug work
The completed pioneer tuner mounted to the factory tuner bracket
After i installed the unit (sorry crappy cell phone pic)
enjoy!
enjoy!
Very nice. Ill be using the knowledge you just gave me when I upgrade down the road. I mostly listen to XM so its good to know I can use the factory antenna with the A/M HU.
thanks for the info i was thinking of renewing my sirius but now i know i can use my stock antenna for xm i may just go back to xm and how long was the wire to go back to the deck, i have a pioneer 4100dvd unit
nm, ebay does have a 15 foot cable if the one that comes with the tuner is not 15 foot to go from the back to the deck
killer, ive been looking into doing the same deal with my factory xm tuner. im still scouring the webs, but does anyone know where the tuner is on a 4 door? im thinking under the rear seat or the rear deck.
yeah im sure it is, real quick, does anyone know where in the car the stock antenna is ran from? i had the head installed and im probably going to have to dig for the stock antenna plug.
This actually helped my out! Thanks OP!! I never would have thought to dremel the original XM connector, got everything hooked up and it works as if it was stock. Only problem now is that i gotta figure out why the sound on my XM is quieter then the other sources i have... dont think thats an xm thing though, im guessing its more to do with the deck.
Damn I wish I saw this posting about a year ago, it wouldve def helped me out, instead I just took off the plastic lock on the factory plug and dont have it anymore, oh well nice idea just the same.
