Prefab Sub Box
Prefab Sub Box
Hey can anyone hook me up with a link to a prefab box which can fit in the trunk of our Cobalts? I'm looking for a 32hz slot vented box if possible (prob not) and square cut outs (if not well mod it our selfs)
Thanks in advanced!!!
Zenclosures.com has them for the balt and you just have to let him know if you want the square cut-out
i had basically the exact same set up but with different batteries and some damp pro and i dobut it was even close to 151
i have seen 2 10's hit 155...with a custom tuned box, correct power supply, and a good amp....for a MMATS Pro Audio amp 151 is not even that crazy if we had more trunk space I would be doing 153+ with 1550 rms (I plan on upgrading to 9500's or maybe even swallow my pride a look into the RE mt's)
thanks for the link!!!
jw the box on that site why only 2dr...? I didn't even know their was a difference in the opening?
Last edited by musifreak190; 07-11-2009 at 02:38 AM. Reason: Automerged Doublepost
hmm we built a wall with 4 15s that did 153 on the TL... never tuned it just built it the day before the comp and the owner went to jail a month later (he was mod 1001-2000) http://caraudioevents.com/Event%20Re...nt_2_23_08.htm
i know sure as hell u cant do that with 2 L7s not on a term lab
oh god please stop...look I am friends with Whitey under pressure(who does 174.4 w 4 15inch subs) he builds our boxes don't tell me you cant do 151 with two l7's
this is what I do
J&S Audio ALL DaY BABY
We came in first at the last ave sound comp. for the two 15inch class
this is what I do
Last edited by musifreak190; 07-11-2009 at 02:57 AM. Reason: Automerged Doublepost
Ok I want to know what Joe Labato is running to do 182.2 (Sound FX, 10/11/08)
But I agree if you are friends with a builder then why the hell would you want a pre-fab?
That would be like living next door to Thumper and going to best buy and getting a bassworks...it just don't make sense.
there is some guy in Australia doing high 180's with don't quot me but I believe 1 12 inch...definitely just one it may have even been a 10 inch
and I am having a box built right now but its going to be a while before he gets it perfect..and I need something fast.
So you just want a temp box, that makes more sense. I don't know if your going to get anything tuned to the freq you want in a pre-fab but as long as you stick to something thats, I think the numbers were 15" high and 32" wide but I may be off by and inch or 2 on the hieght, it may 17", Emp will know for sure. Anyway thats the demensions of the opening for the back seats into the trunk
And are you looking for something like this
http://www.woofersetc.com/p3780/KKP2...Ported-Box.htm
I think we are looking at it from 2 different sides. You talking about what is possible and im talking about what is reasonable. Pretty much anything is possible but a consumer with a single 10 or even a retailer taking a single 10 to a comp isnt going to do anything like that. Even big competitors aren't bringing those numbers to the table. Just because u read something on the net doesn't make it true.... I'm not trying to talk **** about you or your shop or anything I'm just trying to get everyone on the same page. The way you make it sound is getting high numbers is easy... and ill agree with you give me a single L7 a couple thousand watts and a CRX and i can do a burp box that will get loud as hell (blowing the sub in the process but whatever) get that same L7 in a normal daily box in a normal car off a normal electrical system and there's no way those numbers can ever happen. 150db on the termlab is loud as hell and getting there is pretty hard. and its exponentially harder to get louder after that
I think your talking about the guys from Brazil who set the record with 1 18" DD, (high 180's) but there could be someone from down under.
its a USACI thing... mic is in the port... port wars utalizes the globe (8" diamater around the mic) so you need a port bigger the 8" to fit it inside, super port wars is the mic as is and you can do whatever you want with it
oo that's crazy but kinda cheap but still cool, and yeah i think that guy was from Brazil I heard he threw away thousands of dollars in different setups (he's supposedly filthy rich) I didn't think it was an 18" tho,
any way I decided I want to go with 2 10 inch 9500's instead, I found a vented box which has 2.5 cubes and I was wondering if you guys think that's enough?
http://www.sonicelectronix.com/item_...x-+2SBV10.html
It should fit no problem also, but I read in the manual of the 9500 10 inch that they say to build a box with 1.45 cubes a piece and mean while the MTX website says 1.25 cubes...so a 2.5 box I found I figured would be perfect but than I read that in the manual....You think the .2 is gonna make a difference?
sorry but thanks in advanced...
lol
