problem with amp/subs
all of the sudden my subs started skipping beats realllllly bad, sometimes it would just shut the subs off for a few seconds, while other times it would just miss a beat in a song and keep going. ill list off what ive done so far to try and correct the problem.
adjusted gain/crossover freq.
reconnected speaker wires from amp to sub box
reconnected wires that connect the subs to the sub box
adjusted EQ settings on deck
reconnected power wire from amp to battery
unplugged 1 sub at a time to see if it was a problem with 1, but all 4 did it.
reconnected RCA's on both ends amp/deck
if anyone has any ideas that would be great.
EDIT: this only happens when the volume is turned up (not close to max volume though) so I think it might be clipping, ive never had a problem with it so i have no idea what it sounds like or how to fix it.
EDITX2: its a rockford t40001bd with 4 boston g5's and the gain is only turned about 1/3 the way up and crossover freq is at 130, the "clipping" occurs regardless of how high or low the gain is, right when i turn the volume up on the deck it starts up again. It happens on every song and my ipod, CD, and radio.
can you replace amplifier internals? or would I need to buy a new one
clipping...or amp issues...i was HUGE in car audio is could even go all the way down to the alty...check your ground and remote wire...put a volt meter on the battery while that **** is hitting at max you listsen to it at,,,if it drops below 12v then you need to turn down your gains...did you tune the amp as well to match a certain tone like 50 hz or 45 hz? and box dimensions plzz
just regrounded, and i dont see how the remote wire would affect it, as im pretty sure all it does is effect when the amp is turned on by whatever notch the key is turned to, if that makes sense.
this happens even if gain is at lowest setting. and i have always had the gain at the same setting and i didnt change it before this happened.
i did not
i dont see why that matters, its a custom box and its not a rectangle, all i can tell you is that its ported and each are 1.3cu per sub
and no different smells, but theres been a smell when i bump it, but its always done that.
no and no, im most likely going to buy a new HU if i can't get mine fixed, I would have already had it installed if the wiring kit wasnt 120 ******* dollars.
if i can get the radio to work
0 gauge
is your distribution block and inline primary fuse holders AGU? if so replace fuses, weather likes to do a number on those, i was scratchin my head for a while when i had that issue. also, get your dmm out and check the voltage of you remote turn-on wire i believe you need at least 1.5volts (some one correct me)
EDIT: Wait, i just read about the smelling thing..... do your subs sound like floppy dog turds? and clicking like when they are hitting... youd have to open the trunk and have a listen.
emperorjj1 im thinking maybe spider detachment caused one vc to break? and basically having some mechanical problems causing electrical ones.
1. sounded fine but would get VERY loud for like a 1/2 second on high notes/tones
2. subs started cutting in and out when i turned up volume on HU, but actual music still played
3. radio stopped turning on, amp/subs still turn on though.
brick everything and start over.... dont know what else to say, wire everything with new wire get a h/u if its under warrantybuy new fuses (including the fuse that your using for a remote wire) for both h/u and amp. try a different source for remote maybe? I use the fuse for sunroof motor its 15amp i think.
if that amp gets loud by itself right b4 it goes out, its either a spike in the signal or a bad cap in the amp.
i would just buy all new **** to be honest
sounds like the amp is ******* up your electrical still. I'm not 100% sure what the exact problem but almost everything sounds like its a voltage issue.
check to see where you have the remote on the amp tapped to. oh and it doesnt really have to do with ur issue but the crossover is way to high at 130. try 80 or lower
Have you tried re wiring them in series to drop the load to 4 ohms and then ajusting the gain to match the output needed.
The difference in power draw from 1 to 4 ohms is alot even if the amp is turned up at 4 ohms it does not seem to have as much of an effect as it turned down at 1 ohm.
Some amps are just really picky about there setup
looks nice, i only have 100 though cause of xmas shopping!
if it was all "professionally installed" then the installers should be able to figure out why its doing that.
and yes spun is correct. at a higher impedence the amp is more efficient making it draw less current. Power output will be different thou but in a few cases it wont be noticeable just listening to it. I did test this out when i only had a single XXX 15, 1ohm vs 4ohm on the T30001bd
new HU for me i guess...
