Problem with something
just look at my sig and help me out
I was at a party and my car was the music car for the party and i didnt want anyone to put it over 20 but when i got back to my car there was no bass and the volume was at 35!!...
I was looking at my system lastnight and my fuse is still in good condition but my amp doesnt turn on and my subs dont hit anymore. i also looked at all the wiring and nothing is melted or dissconnect.
Whats wrong with it?
What fuses did you check? There should be at the very least a fuse on your amp and then a fuse on the power wire that goes to the amp.
I assume you get some music since you just say there is no bass, but if you get no music also check the fuse on your head unit, and the fuse that is tapped for the HU power.
Some people also will fuse thier remote wire for some reason so that might be something else to check.
Does your amp have a light on it? And if it does have a light what color is the light if it lights up at all.
Ground wires are something that can randomly get messed up. Where is it grounded and is there paint on the surface where it is grounded? If there is paint then you need to strip the paint and reground it.
like others have said i would check ALL fuses, in the power wire, the head unit itself, and also on the amp. Also just double check, and triple check wiring....sometimes its hard to miss.
Theres 5 fuses on the amp so ill check it out tomorrow... My amp lights up blue on the lcd but the screen doesnt turn on or do anythin
im just gonna take it in tomorrow where i bought it for warrenty if my amp really did blow
thanks for the help
thanks for the help
