Projector
Projector
does anyone know which fuses control the headlights? specifically the left headlight? ive had a halo, 3 LEDs, and one orange marker die on me in one day when i was installing my HIDs, and the HIDs dont work either (they work in the right headlight) the only thing i can think of is that the fuses blew....but i dont understand how one of the halos and one of the orange bulbs would still illuminate if the fises were blown, but everything else be dead
ive checked all the connections as well...
Original Hayden Fanatic
they are wired in series, so if one goes out the current shouldnt travel to the others...
if you do need replacements & cant get them from the vendor/seller then PM mkurly & he will give you a good deal on replacements
well, i pulled out just about everything...and i came to a really gay conclusion. Fuses are fine, wiring is fine, everythings great. however, 2 leds on the pass side, all 3 leds on the right side, one right side halo, and both the right side HID high beam bulb and right side HID low beam bulb blew within 1-2 days of each other.....i really have NO clue how this happened...i guess sometimes this **** happens, but im more concerned with it happening again to the headlights once i get t fixed. Im probably just going to order a new set of projectors since it would be too much of a pain re soldering all those LEDs and i scuffed up the projector housing anyway when i was troubleshooting. Anyone have a place that sells good (long lasting) projectors other than CA?
