Projectors wont turn on
Old 12-17-2013, 02:06 PM
You havent even looked at the bulbs yet? Lol. Well stick your multimeter to read Ohms, DO NOT hook the meter to a powered circuit while reading resistance. See if your meter has a continuity function. If it does, read the manual on how to turn it on and what the beep and no beep means from the meter. If not, just stick both leads to the positive and negative sides of the bulb. If the meter reads infinite resistance or OL then they are toast. If you get some number(not sure what the resistance of an hid bulb is) they would be fine.
I actually just did some research. This would work with a normal bulb but not HID. You might need to use diode test if your meter is capable.
Old 12-17-2013, 10:43 PM
Manopka's Avatar
Originally Posted by LS6Rally
ok so where did you get that 12V from, I believe your ballasts should be putting out more than 12V.
Well I was told earlier in the thread that it should be around 12V.
I looked at them but from what I could tell they looked fine. I'll see about the diode thing
Old 12-18-2013, 05:49 AM
LS6Rally's Avatar
do you HID's in your fog lights?
Old 12-18-2013, 01:47 PM
Manopka's Avatar
I don't have fog lights. Car was missing them when I bought it.
Old 12-26-2013, 05:18 PM
Manopka's Avatar
Finally found out the problem
So I finally figured out what the problem was: relay harness.
I went to a local store by my sisters place and was going to buy new ballasts but they actually went out to my car and helped me troubleshoot what the problem was without charging me. They used one of their ballasts and my bulbs work. Then they used one of their bulbs and made sure my ballasts work.
That leaves the relay harness. But before we could get any further the old man owner told the workers that if they keep helping me theyd have to charge me.
So now the only thing im not sure of is if its the actual relay harness or if the its just the connectors(they were extremely corroded).
Old 12-26-2013, 05:32 PM
Well clean up the connectors and use some dielectric grease on the connectors. Then if that doesn't work buy a new relay they're fairly inexpensive
Old 12-26-2013, 08:23 PM
Manopka's Avatar
I plan on doing that tomorrow.
Since my HID system includes a relay harness does that mean the DRL issue should be bypassed?
Old 01-04-2014, 11:53 AM
Manopka's Avatar
Bought a new relay harness from retrofit source. Finally came and I hooked it up and wahlah. Lights come on just fine.
Old 01-04-2014, 01:54 PM
sLAsh's Avatar
If you have the latest morimoto ballasts that it's probably where your problem is. The latest version has problems firing when they get cold. Check on
Update: Morimoto 3Five and 5Five DSP Ballasts
Old 01-04-2014, 07:33 PM
Manopka's Avatar
Yeah I don't think that was the problem. I installed a new relay harness and everything works great now.
06MetallicBalt
08-17-2021 03:40 PM
Solaris99
28
03-15-2017 01:22 PM
RaginChopsuey
10-27-2015 01:27 PM
roth
09-26-2015 12:16 PM
Quick Reply: Projectors wont turn on
