Putting Stock Pioneer Sub In 2.2
So I've come across a stock Pioneer sub/enclosure from the 7spkr setup from GM. My wife's LT was not equipped stock w/ this as an option. I checked around and could not see a clip hanging out for the sub behind the liner. Thought all cars were wired the same, just some used all the connectors and some didn't depending on the order. I dunno anything about audio. Any input? Also, my SS has bolts in the body that hold the sub in w/ nut/washer. Will I need Sheet Metal screws to install this in her car?
The cable should be there. Does she have tweeters in the top door sails? I'm not sure but id assume they ll have the same amp If you have the pioneer back speakers shouldnt be a problem. pioneer speakers in balts are a different impedance so the sub can tap into them and retaina 4 ohm load. if not pioneer dont attempt it get a small amp use hi lo converter
