Question about a battery isolator.
So I know how to wire up a battery isolator. I have the isolator. Run a power wire from each post of the isolator to each + battery post. Then a true igniton source and a ground. My question is, how does the second battery get charged from the alternator? Is it when the true ignition turns on, the charge going to the main battery then goes to the second battery as well?
yes but wiring in parallel causes them to drain each other so they are both equal. So a 14 volt and a 10 volt will equal out to 12 volts each which isn't what I want.
not really sure what you mean since most car batteries are 12v...you can get higher voltage ones but ive never head of a 10v?
Mitch
You need an isolator for two batteries or it will kill both batteries they drain and equal out which just kills it. When you receive power from the true ignition source it allows the batteries to basically be in parallel to charge both batteries off of your alternator and allow your vehicle to pull from both batteries during starting, when the power shuts off the batteries disconnect from each other and keep it from draining.
Mitch
See thats whats weird my instructions says nothing about alternator just a true ignition source. I think I will just go with the fuel pump fuse will make it a little easier I think. I had read on some tutorials to use the alternator so idk.. Either way I will make it work.
