Quick Audio install Question (pioneer D3)
Where do Is wire up the speed sensor (pink wire) for the navigation?
And where do i wire up the e-brake sensor?
Thanks!
i have the e brake wire figured out but i still have a question about the speed sensor...
Thanks!
Last edited by Cobalt_SSTuner; 06-18-2008 at 08:23 PM. Reason: Automerged Doublepost
I thought it needs to be wired up for the navigation to work?
on the d3 harness there is a pink wire that is suppose to go to the VSS (vehicle speed sensor ) and in the book it says that you need to wire it up. But I also heard somewhere that if your vehicle has the feature where when you speed up and the volume goes up (and goes down when you slow down) like we do, then you dont need to wire it up. so i'm a little confused lol
Last edited by Cobalt_SSTuner; 06-18-2008 at 08:44 PM. Reason: Automerged Doublepost
surely it will work without it
the picture is here: http://www.the12volt.com/installbay/file.asp?ID=715
but it requires you to register. I'm registered and it's taking forever to load
but i saw it there yesterday morning
Looks like their site is having problems... The only thing i remember is that the clip is very visible towards the top
Last edited by bgbearcatfan; 06-18-2008 at 08:48 PM. Reason: Automerged Doublepost
