Radar goes off on Throttle?
Old 03-30-2011, 08:27 AM
MastaShaKe_88's Avatar
mine does the exact same thing but starts to work right whenever I talk about gettin a new one while I'm in the car(I must've gotten the female one ) I jus ignore it most of the time or push mute unless Im doin 70+
Old 03-30-2011, 02:23 PM
N1ckateen's Avatar
well my only problem with that is i still want it to detect when it's going off because the majority of the time it's going off because i'm in the pedal.
Old 03-30-2011, 02:38 PM
heathkidder's Avatar
thats wierd my cobra doesnt do that
Old 03-30-2011, 02:46 PM
AWD > FWD
TommyP's Avatar
Originally Posted by TrueRedMS3
I had the same thing happen with my old radar too! I had an Escort 8500. I could never figure out why it would do it. I just figured that something was wrong with it and when you really got on it, it made something in the detector move and set it off. I really don't know why it did it, but since you and others have had a similar experience I'm guessing it has to do with the force of the acceleration.
I highly doubt it's that, because mine doesn't do it in my SS/TC. I've got the same radar detector. It's gotta be the drive by wire system or it's a voltage spike through the cigarette lighter.
Old 03-31-2011, 04:22 PM
TrueRedMS3's Avatar
lol like I said, I was only guessing, I don't know why it does it. It could be a voltage spike as well. But at least other people have had the same problems and I'm not the only one.
Old 04-01-2011, 08:10 PM
N1ckateen's Avatar
wonder if it would still do it if i plugged it into the other lighter then
Old 04-01-2011, 08:16 PM
nikemax21's Avatar
yeah but u said u tried it in your friends mustang as well with the same results, so therefore u can only guess the radar detector is bad.
Old 04-01-2011, 08:18 PM
N1ckateen's Avatar
he has the same radar detector. only difference is mines a 9 band his is a 6 band.
Old 04-01-2011, 08:32 PM
nikemax21's Avatar
ohhh gotcha my bad. how is are the radar detectors? u and ur buddies.
Old 04-01-2011, 08:35 PM
05Slowline's Avatar
maybe it's picking up the gay signal from those foot lights
Old 04-01-2011, 10:33 PM
  #36
N1ckateen's Avatar
Old 04-02-2011, 04:02 AM
  #37
Nighthawk243's Avatar
It is falsing like that because it hurts to live.
Old 07-06-2011, 11:44 PM
  #38
xxxxsh4d0wxxxx's Avatar
I know this is bumping an old thread but my radar did this also, and some of you may still be dealing with this.
SOLUTION: Hard-wire it.
Problem solved. 110% guaranteed. I have no clue why this worked, but it did. I was told this by a friend who works at an audio shop.
Old 07-11-2011, 05:29 PM
  #39
N1ckateen's Avatar
well thank you for the info. i'll have to do that because it's driving me insane lol. what would u reccomend hardwiring it to?
Old 07-11-2011, 08:20 PM
  #40
Fuse tap into the wiper fuse. Behind the passenger kick-panel, for power.
For ground, there is a bolt right below the box of fuses, connected to the frame. You can't miss it.
Old 07-11-2011, 08:57 PM
  #41
N1ckateen's Avatar
good deal! i'll do this right now =)
Old 07-11-2011, 10:35 PM
  #42
Let me know how it goes! You'll have to cut the cigarette part off of the wiring and split the positive and negative away from each-other and wire strip them about 4".
Old 07-11-2011, 10:36 PM
  #43
N1ckateen's Avatar
works like a charm! 3 ****** birds with 1 stone right there! no cigerette lighter use now. even less wires. and no beeping! thank you so much man!
Old 07-12-2011, 11:25 PM
  #44
No problem bro! Just make sure ya give me credit!
Old 07-13-2011, 12:19 PM
  #45
N1ckateen's Avatar
haha the credit's all yours. only thing different is i wired it to the sunroof fuse instead lol. works like a charm though woo woo. i'm excited cause i was just about to buy a new detector.
Old 07-13-2011, 07:09 PM
  #46
Old 07-13-2011, 11:35 PM
  #47
N1ckateen's Avatar
hey btw! i see ur only in illinois. you should come to our indy meet next month and if u have any buddies in illinois they should tag along!
https://www.cobaltss.net/forums/mid-...l-meet-253270/
Old 07-14-2011, 10:39 AM
  #48
im bout to try this today.. well its not really tryin cuz you can plug it back in the Cig lighter afterwards
Old 07-16-2011, 05:44 PM
  #49
Cobalt08LS's Avatar
seems like a defective radar to me. i had a cobra. stopped using it for a while than i wanted a radar again so i sold it and got a beltronics rx 65. i love it!
Old 07-17-2011, 12:43 PM
  #50
For sure, sounds good! I'll check it out.
No, you will need to cut that part off.
Not exactly. It is (to the best of my knowledge) a problem with voltage dropping when there is a fuse in-line with the circuit. The cigarette part does have a mini tube-fuse in it. But, as soon as you remove that part, no voltage drop. Not sure why, but it is what it is.
DarrenGC
12-24-2021 01:55 PM
10-13-2015 09:32 PM
n20saturn
Drag Racing
19
10-06-2015 12:38 PM
Adiaz1ss
09-26-2015 11:51 PM
yellowsupercharged06
09-15-2015 04:38 PM
Quick Reply: Radar goes off on Throttle?
