Radio changes equalizer automatically
My radio will change the equalizer to 2 notches up on bass and treble for no aparent reason it seems. I will set the equalizer to be even on bass and treble then change the radio station and it resets itself to 2 notches on bass and treble. BTW this only happens on the radio stations and not when you change tracks on a cd or mp3 disc.
It is a feature. The radio saves the EQ settings when you set the presets. It also saves them for the CD and AUX inputs. If a station doesn't have its own setting it goes to the default for the band (AM/FM). You have to set it for each if you want different settings on different stations.
agentirons
10-16-2015 02:11 AM
