Radio is extremely quiet? Need an expert!
Old 04-26-2011, 08:25 PM
LSJ
LSJ's Avatar
Originally Posted by ecot3c inside
sounds like a wire is shorted somewhere, when I had some nice subs they went out randomly a couple times and finally figured out it was either a wire shorting to ground or the amp was up too high and going into protection mode. I forget. but give me a call tomorrow, I get out of work at 4pm maybe well hook up.
I highly doubt it is shorting, I would say the part itself will go bad before the wires. I will call you, definitely!
Originally Posted by zrated89
hers did the same. Its an electrical part going bad
Really? Was it exactly what I described?
Old 04-26-2011, 08:28 PM
zrated89's Avatar
yes sounded quiet, and almost sounded like she had no sub at all. But it would do it intermitently as well. Its not hard to swap try your buddies for a test then pick one up. I would say junkyard dealer will charge out the ass. Hers was warrantied
Old 04-26-2011, 08:37 PM
LSJ
LSJ's Avatar
Exactly, I can't even hear the sub. (Granted my bass selector is in the middle, I can usually hear the sub easily.)
Definitely intermittently also.
From all I've read it is a BITCH to get out?
Old 04-26-2011, 08:52 PM
EmperorJJ1's Avatar
the sub? the sub is easy to get out but you have to take out the entire box
Old 04-27-2011, 12:23 AM
LSJ
LSJ's Avatar
No no lol, the amp.
Old 04-27-2011, 08:35 AM
zrated89's Avatar
ALLDATA Online - Logon
click the link its actually not that bad ive done them as well
Old 04-27-2011, 08:54 AM
YelloEye's Avatar
Cool login screen
Old 04-27-2011, 01:23 PM
LSJ
LSJ's Avatar
Originally Posted by YelloEye
Cool login screen
x2
Old 04-27-2011, 01:28 PM
zrated89's Avatar
was at work forgot the public cant see that site. The amp is in the lower dash on the drivers side
Old 04-27-2011, 03:17 PM
sLAsh's Avatar
https://www.cobaltss.net/forums/prob...elerate-30515/
Auto volume
Old 04-27-2011, 06:26 PM
  #36
LSJ
LSJ's Avatar
Originally Posted by sLAsh
Negative.
Old 05-08-2011, 05:20 AM
  #37
EmperorJJ1's Avatar
ya the amp is sorta a bitch to get out sometimes. idk ive done it fast a few times too so
Old 05-08-2011, 08:28 AM
  #38
scottydoh's Avatar
I'm having the exact same thing happen, except only with the front speakers, specifically the front drivers side. And I have the base speakers (LT, as low as you can go) and the HU is stock. I'm thinking bad speaker?
Old 05-08-2011, 07:10 PM
  #39
EmperorJJ1's Avatar
yup sounds about right
Old 05-10-2011, 07:27 PM
  #40
HmF300ex's Avatar
Didn't really read through the thread but its not the speakers, they would be rattling if they were blown. It can't be the external amplifier since the highs/mids are quieter, not just the bass. I HIGHLY doubt it's a bad connection as that would probably onle affect one speaker and there would be sound distortion. If it only occurs when listening to the radio then it MIGHT be reception issues but that should cause distortion too, did you just get your windows tinted? I highly doubt it has anything to do with reception. So it must be the H/U. I would just take it into a shop or replace the headunit. I don't know any details about the stock headunit, if it is internally MOSFET amplified, it sounds like something with the MOSFET got messed up and it's sending un-amplified/partially amplified signals to the speakers.
The easy stuff you probably already checked: If your using AUX, make sure your mp3 player's volume is all the way up and check the balance/fade on the headunit. It sounds like something that is not fixable from your position, it sounds like something internally with the headunit.
Old 05-10-2011, 11:23 PM
  #41
SS SCHGD's Avatar
what year do you have? I have a Radio from a 06 SS/SC if you end up needing a new one.
It sounds like a Head unit problem, unless the stock amp is dying. I know the Stock headunit for the Premium Pioneers puts out a low power signal, usually sent to the amp, maybe if the amps dead you just get the low signal from the stock headunit sent through the amp without it being "amped" up, and it goes out to the speakers then?
(I have a stock amp too if you need it)
Old 05-11-2011, 02:09 PM
  #42
LSJ
LSJ's Avatar
2006 SS/SC I've narrowed it down to the HU or the factory amp. Not sure which. Most electrical failures like that are just bad luck, you really can't prevent either of those from breaking.
How much would you like for each/both? How long were they in the car?
Old 05-12-2011, 10:52 PM
  #43
SS SCHGD's Avatar
The amp was in the car for about 6 months, the headunit about 2 years. I'd like to get $50 for both? They both were working fine when removed, and have just been sitting in a box since. My Headunit was equipped for XM, Onstar, and MP3. It's silver and hasn't lost any of the labels on it.
Before I'd pick up new stuff, I would wiggle some wires at the amp and headunit and see if you get anything though, maybe you just have to troubleshoot a bad wire (Amp turn on wire?) and you'll be ok... Are you running aftermarket subs and amp?
Old 05-13-2011, 02:00 AM
  #44
EmperorJJ1's Avatar
i would try the amp first then the HU. its a bitch to get to the amp but if thats the problem then it will save you the money to pay the dealer to reprogram the HU. IMHO its probably not wiring but really 50/50 on if its the hu or the amp
turboecotec02
11-26-2015 10:43 AM
chefhhr
10-26-2015 10:36 PM
agentirons
10-16-2015 02:11 AM
Extremespeed
09-29-2015 04:34 AM
09-26-2015 06:44 PM
Quick Reply: Radio is extremely quiet? Need an expert!
