Rear Deck Speakers
Rear Deck Speakers
Has anybody tried installing these speakers (or any others from Polk Audio) in their Cobalt? I'm thinking of replacing my factory rear deck speakers, and these seem like a really great deal:
Polk Audio DXi690 6"x9" 3-way car speakers at Crutchfield.com
Considering your new head unit has a 4ohm internal amp that is sending to the 2 ohm factory before the speakers, I would instead invest in new amps and running your speakers off of the RCA's > new amps > speakers.
4ohm head unit > 2ohm factory amp is a restriction to the speakers that is going to cause distortion and clarity reduction.
Getting a new amp or doing an amp bypass utilizing the radio's internal amp may still be good options however if you are going to do so you will want to replace the front speakers as well due to the tweeters specifically
EmperorJJ1- When I installed the new Pioneer head unit, I just connected the speaker wires in the wiring harness to the speaker wires on the back of the head unit. Is that what you're talking about?
Sorry, this is all rather new to me...
then ya u are using high level inputs. This isnt a problem as long as you arent blasting it louder then it would have been "stock"
The easiest option will be to find 2 ohm speakers to replace the rears. The best option will be to do an amp bypass and replace both fronts and rears (with or without a 4 channel amp). and the worst option would be getting 4 ohm speakers and replacing the stock ones with those
honestly i have no idea andrew. and yes i did an amp bypass how to
https://www.cobaltss.net/forums/elec...bypass-106315/
Emperor- What about these for 2-ohm replacement speakers?
http://www.sonicelectronix.com/item_...tml?show_tab=1
http://www.sonicelectronix.com/item_...ce-9633cf.html
DANRICKARD
10-01-2015 12:08 AM
Delta coupe
09-30-2015 08:11 AM
