rearview mirror 16 pin connector help
Ok so I just found my rearview mirror with autodim, compass and maplights, with NO onstar, got it out of a 07 HHR. I got a connector with some wire with it and have all the wires figured out except the wire in position 6 wich is a blue w/white stripe. Does anyone know where that goes or what voltage it should have?
I found it. For anyone wanting to do this upgrade it is very easy. I now have fully functioning autodim, compass, maplights and the maplights also come on and dim off with the dome light
im interested. post pics of mirror and everything if you can.
i haven an 08, no sun roof, that came with on-star. I cancelled onstar so i dont need the mirror buttons anymore. my mirror does NOT have map lights as i have a dome, but i would love map lights and a compass (don't care about auto-dim, although it would probably be nice to have)
Inside Rearview Mirror (DD8) Pin Wire Circuit Function
1 0.35 GY 157 Interior Lamp Control
2-5 -- -- Not Used
6 0.35 D-BU/WH 149 Courtesy Lamp Supply Voltage
7 -- -- Not Used
8 0.35 BK 750 Ground
9 0.35 L-GN 24 Backup Lamp Supply Voltage
10 -- -- Not Used
11 0.35 D-GN/WH 2514 Keypad Signal (UE1)-- -- Not Used (DD8)
12 0.35 L-GN/BK 2515 Keypad Supply Voltage (UE1)-- -- Not Used (DD8)
13 0.35 PK 339 Ignition 1 Voltage
14 0.35 YE/BK 2516 Keypad Green LED Signal (UE1)-- -- Not Used (DD8)
15 0.35 BN/WH 2517 Keypad Red LED Signal (UE1)-- -- Not Used (DD8)
16 -- -- Not Used
