Red projector halo's
Old 04-23-2012, 09:35 PM
AWD > FWD
TommyP's Avatar
Originally Posted by mheidelman
i have halos i just need the colored ring im tired of the blue it came with
but i cant find them
could u post a link ?
your gonna have to find what size halos you need. No matter what you do you're going to need to open up the headlights and swap in completely different halos, unless you have a set of gen 1 projectors then you can just change the led bulbs.
Old 04-25-2012, 02:18 AM
EmperorJJ1's Avatar
Originally Posted by brickloaf
Might be a dumb question but is it possible to make the halos on projectors like up red and run as DRL's like bmw's but still be able to use my 10k hid bulbs at night?
swap out to red led then run the power wire to an acc fuse/wire (you can and should throw a switch in line too)
Old 04-26-2012, 02:02 PM
brickloaf's Avatar
I had red LED halos for about a week but they were burning out every other second....i want CCFL's sooo bad but im not confident in my ability to take apart the headlight and put it back together w/out making it look like ****
Old 04-26-2012, 02:04 PM
EmperorJJ1's Avatar
where did you buy the leds from? specifically what voltage were they meant to be ran at
Old 04-26-2012, 02:06 PM
brickloaf's Avatar
no idea what voltage but i got em from buyhids.com
Old 04-26-2012, 02:15 PM
EmperorJJ1's Avatar
and of coruse they dont say. see if you can find out what voltage they are from them. bc if they go out that fast on that consistent of a basis then they probably arent 12v leds (or less with built in resistors) and ud need to wire in resistors for them. that would fix the problem of them going out so often but they will also prob get dimmer
Old 04-26-2012, 09:11 PM
mheidelman's Avatar
sweet thanks !, what size should i get ?
Old 04-26-2012, 09:13 PM
AWD > FWD
TommyP's Avatar
What are they going in? You will need to either take the headlights apart and measure the current halos, or find the measurements somewhere on the site depending on what application you have.
Old 04-26-2012, 09:42 PM
C_A_D88's Avatar
The mini h1 retros are 70 mm
Fog lights can use anywhere from 60-75
Or u can get 60 and 75 and run dual halos on the fogs lol
Old 04-26-2012, 09:48 PM
IRS_Will's Avatar
Those lights make it look evil
Old 04-28-2012, 01:09 PM
  #36
brickloaf's Avatar
at this point i just want CCFL's
Old 04-28-2012, 05:42 PM
  #37
EmperorJJ1's Avatar
ya i agree going to ccfl was sweet
Old 04-29-2012, 08:45 AM
  #38
mkulrey13's Avatar
Our LEDs are 12v. Our new leds come pre-wired with resisters as our old ones do not. The resisters in the projectors suck which is why the leds burn out so quickly.
TedSS
101
04-25-2016 10:46 PM
chefhhr
10-26-2015 10:36 PM
09-27-2015 08:53 PM
09-26-2015 06:44 PM
dieGone
09-23-2015 10:20 AM
Quick Reply: Red projector halo's
