Relay wiring question
Hey,
I wanted to know if this is possible/correct/safe to do.
I currently have one relay being "activated/triggered" by a switched power source from the interior fuse panel. I used an "add-a-fuse" to the wiper fuse. That wire goes to 86 on the relay.
I now need to activate/trigger two more relays, would I be able to activate my other two relays from that one fuse? I was thinking of twisting three wires and soldering it to the tapped fuse, each wire from the tapped fuse would go to a separate #86 pin on the relay.
I used my test light and couldn't really find any other non-important switched fuses.
Thanks
Edit: below is a picture of what I am trying to do...
Each relay has it's own ground, and lead from battery, just want to know if I can have a shared switched source or does each relay need to have it's own switched source
Thanks
It depends on your current draw. If your just using it to power the relays your fine. However if you start using it for the main power source of a amplifier or a beefy compressor you e will have problems
Just out of curiosity you don't know the max number of relays I could be able to use?
Hey,
Sorry for the late response, but I would like to follow up on this thread.
Emp I am using the wiper fuse to trigger three relays at the moment, it's been about two weeks and haven't had any problems thus far.
