Remote start question??
I have everything connected have the xk09 updated and and viper module 4704 2 way remote and unlock, lock, trunk everything works.. Only thing is, is that the car wont turn on, i have the ignition power but it wont crank. Any help guys?? im almost done with it just this issue.
For mine to work you have to have foot on brake and clutch. Put tranny into neutral. Release clutch FIRSt, then brake. Car continues to run when you remove key. Shuts off engine and locks door after you close it.
Other remote starters may use different sequences to ensure car can't be remote started in gear so RTFM.
I doubt his issue is not being able to get it set.
