Replaced stockies with aftermarket
Former Cobalt Owner
I just replaced all 4 speakers with some aftermarket Pioneers 6.5s and 6x9s. Im glad to see that the 6x9s actually fit in the holes unlike the cavalier i had. But that on part i had trouble with was the rear pillars. the damn plastic piece with the metal clip on the end kept folding over when i was tryin to put it back on. Finally i got it but i hope i wont have change them out again haha. But the speakers sound a whole lot better than stock. Now i just have my flip out and my subs/amps with the custom enclosure to put in.
Former Cobalt Owner
yeah thats what i was not hoping for was to mount them underneath haha. But they fit perfectly in the holes. putting the rear deck back was a pain
Mounting them underneath wasn't that big a deal. All you have to do is take the screw hole insert thingys out, turn them upside down, then pop them back in. I even used the 2" screws that came with the new speakers and they weren't long enough to hit the rear deck panel. That surprised me. There's actually quite a lot of room underneath that thing.
I never took the rear deck lid out. It bent just enough to get underneath and pull the stock speakers out, even with my big arms shoved up in there.
I just ordered my 4 speakers to replace the stock ones. For the doors I'm putting in 6.75" Kenwood 1789ie's, and for the rear I'm putting 6.5" Alpine SPS-170A's.
I'm replacing the 6x9's with 6.5's because I figure if I add a sub in later, it would make for a better setup with 4 mid/high speakers and then a nice low sub for the bass. I can't wait to install these!
Also, if you order from Crutchfield (crutchfield.com), they give you EVERYTHING you need (brackets, wire harness, etc.) plus most of there stuff is shipped for free. I got all four speakers for $140 shipped.
Originally Posted by Kritter
What did you guys use for the door speakers. I understand they are a weird setup power wise?
not its a normal setup unless you have the upgrade then it just splices off to feed the tewweters my boston acoustic components drop right in minus the tweeters had to dril;l out the stocks and flush mount the new ones
Former Cobalt Owner
yeah the pioneer system is a direct replacement....just find out with wire is + and - then connect to the speaker wiring that came with the speakers
DANRICKARD
10-01-2015 12:08 AM
importkiller
09-30-2015 07:18 PM
