Reverse light LED help
Old 11-15-2006, 08:26 AM
Gamebay11's Avatar
I am going to be doing the LED in the reverse light mod, and I am not sure which color LEDs to use. I am afraid that if I use white, they will be too bright, and if I use red they might not be bright enough.
Thanks for any help, and here is a link to the mod in case anyone is wondering:
http://www.hbgstreets.com/index.php?...=article&sid=4
Old 11-15-2006, 08:36 AM
xspyder85x's Avatar
im not sure do one in red and one in white and see which one is better.
Old 11-15-2006, 08:44 AM
rally's Avatar
If your doing your reverse lights by law they must be white. FYI
Old 11-15-2006, 12:53 PM
Gamebay11's Avatar
This is for the red ring around the reverse lights
Old 11-16-2006, 06:15 AM
EmperorJJ1's Avatar
oh for the 3rd brake light... id go red
Old 11-16-2006, 06:31 AM
05REDROCKET's Avatar
Use white leds because the red lense will make it red.
And every other brake light is a white bulb so it will match.
Old 11-16-2006, 06:39 AM
e to the x's Avatar
And don't buy those cheap Pepboys LEDS. Find some that have a nice high intensity and use them.
Old 01-17-2007, 11:47 AM
origami78's Avatar
I was wondering if using white if it would bleed over and look like your backup lights are on?
Old 01-17-2007, 12:02 PM
EmperorJJ1's Avatar
honestly with leds i would go red.... all leds tail lights factory or aftermarket that ive seen have been red not white
Old 01-30-2007, 10:36 AM
origami78's Avatar
I used 24 5mm white LEDs rated at 50,000MCD per backup light
Old 01-30-2007, 10:42 AM
Tung's Avatar
damnn!!! ^^^^^
Old 01-30-2007, 01:48 PM
EmperorJJ1's Avatar
that looks pimp
Old 01-30-2007, 01:53 PM
Gamebay11's Avatar
Damn, i used only 8 per light. Do you just have a mess of wires back there now or what?
Old 01-30-2007, 01:56 PM
tombomb's Avatar
i was just about to comment on how lame this mod looks kuz it doesnt match the stock tailights, but you just proved me wayyyy wrong Origami78! that looks awsome and professional, did you use 24led's/light?
Old 01-30-2007, 02:12 PM
origami78's Avatar
48 LEDs total. 24 LEDs a light. I hooked 4 LEDs in series and then each group of 4 LEDs I have in parallel. I then hooked the negative wire to ground and the positive side to the brown wire on the tail light. I only have 2 wires coming off each backup light. I thought it looked very clean. The LEDs that I put in did not have wires on them. With the way I did it I have 3 ground wires and 3 positive wires hooked to the 2 wires that go out to the tail light.
I used LEDs like this http://cgi.ebay.com/50pc-5mm-Super-B...em250070725753
Old 01-30-2007, 06:34 PM
tombomb's Avatar
so you didnt need resistors or anything?
also do you have a pic or what your wiring methods look like? ie pic of the back of the revers light(showing installed leds)
Old 01-30-2007, 06:48 PM
SS SCHGD's Avatar
How much would you charge to do 2 pairs? They look sweet.
I've got one set on a car in a garage that I can get to you right away, and when they are done I can give you the other set..
Old 01-30-2007, 06:50 PM
Beck's Avatar
wow i think this is going to be my next mod
Old 01-30-2007, 10:06 PM
origami78's Avatar
Here you go night pictures
Old 01-30-2007, 10:16 PM
tombomb's Avatar
wow looks SO sweet, specially when you squint your eyes..
Old 01-30-2007, 10:29 PM
Red06LS's Avatar
Yea this deffinatly looks like a fun and easy mod. Looks good too!
Old 01-30-2007, 10:51 PM
tombomb's Avatar
now shave your emblems!!
Old 02-03-2007, 05:31 PM
origami78's Avatar
I had a defective LED; it started flashing, making the other 3 in series flash also. Since I was replacing it, I decided to take some pics.
Old 02-03-2007, 06:28 PM
Beck's Avatar
^^^ appreciate it. helps a lot
Old 02-03-2007, 07:25 PM
origami78's Avatar
This is the How To that I went to. https://www.cobaltss.net/forums/how-guide-43/how-install-led-lights-into-your-reverse-lights-35528/
Quick Reply: Reverse light LED help
