Second skin inside sub box + surprise
Old 07-22-2009 | 03:00 PM
  #101
brickloaf's Avatar
132db?
oh ya still need that wire. turns out the lift i was gonna use fell thru so
btw i was talking about hz not db, but i dont think 32 hz is hard to hit for most subs...
what brand was it? im assuming its good wire?
Old 07-22-2009 | 03:34 PM
  #102
EmperorJJ1's Avatar
its the schoche EFX wire. looks about the same as stinger (slightly less copper then kicker/fosgate but more flexible)
Old 07-22-2009 | 03:58 PM
  #103
brickloaf's Avatar
well the only 0g i need is the 20-25 feet for the big 3 (minus battery to ground) if you have that much how much $ were you lookin for..
and did you ever get my pm with my diagram about the battery, i get my wires/battery terminals etc etc from knu tomorrow and want to get that bitch hooked up asap!
Old 07-22-2009 | 04:51 PM
  #104
JRANGER's Avatar
I have my system (AMP & Box) tuned to 33hz... Bumps awesome to rap and not bad for rock either
How much wattage you running??? Damn
Old 07-22-2009 | 05:42 PM
  #105
brickloaf's Avatar
only 2500rms, emps got 5k and spun has 3200
and yea i want to tune my box to around 32 hz, i pretty much just listen to rap and songs that hit loooow so 32 should be good
Old 08-30-2009 | 03:20 AM
  #106
EmperorJJ1's Avatar
lux liner in the quarter panel... hope the plastic panel still fits after this. excuse the wiring
Old 08-30-2009 | 06:04 AM
  #107
Spun's Avatar
Hey what size was that torx bit to get the seat belt piece off again?
Was 50, or 55.
Brickloaf- I pretty much well max out at 3000+ give or take (without bench testing the amp its hard to tell, even amps of the same model will vary in there final output) .However when PSAmag tested the 09 T2500-1 it produced a little over 3000w @1ohm with 13.8v . So along those lines all things being equal its safe to say the T4000-1 will produce in the range of 5000w @ 1ohm , now here's the little thing that goes unnoticed, with 13.8 volts
With a 16-18 volt setup like Emp is running the amp has the ability to produce so much more, I can only take a est. guess and say somewhere in the mid to high 6000w range. The problems emp has are 1- Can his subs handle that kind of power, and 2 - the T-2500 had a massive power draw, a quote from the magazine "the maximum current demands of this powerhouse were 310 amps!" So I can only imagine what the draw on the T-4000 must be like.
I don't really feel sorry for him though, these are problems I only wish I had
In a very uncharacteristic like move Emp is just being modist by saying 5000w
Old 08-30-2009 | 06:36 AM
  #108
EmperorJJ1's Avatar
50... most cars are. infact thats the only torx bit i own. 6 dollar bit right there
as an fyi the T4kw comes with a 500a fuse so
Old 10-30-2009 | 11:49 PM
  #109
EmperorJJ1's Avatar
sorry guys these have been on the comp at work for a week and i kept forgetting to upload em... don't worry bout the amp wiring. just trying to show the carpet instead of the spectrum as in the build up
Old 10-31-2009 | 12:30 AM
  #110
outtamymind's Avatar
emperor i take it you don't put passengers in your back seat having your amps attached to the seats eh
Old 10-31-2009 | 12:38 AM
  #111
EmperorJJ1's Avatar
i can. the seats still close with the amps there. i just cant play the subs with the seats folded up.
I need to change out the amps anyway thou. the fosgates arent mine
Old 10-31-2009 | 01:10 AM
  #112
ahh i see. looks good as well forgot to mention that. the FG face looks like a mask when you were test fitting it.
Old 10-31-2009 | 01:22 AM
  #113
CordiaDOHC's Avatar
Damn... had to pour a bit of my drink on the ground when I saw those poor art series amps.
RIP Art series!
guess at least it wasnt some of the old RCA Orions or a Mcintosh or anything like that.
ineedacobaltss
11-07-2015 03:25 PM
dennis69
10-20-2015 05:49 PM
grampss
09-27-2015 09:51 PM
c_m_shooter
09-27-2015 05:40 PM
Quick Reply: Second skin inside sub box + surprise
