Second skin inside sub box + surprise
#101
#103
well the only 0g i need is the 20-25 feet for the big 3 (minus battery to ground) if you have that much how much $ were you lookin for..
and did you ever get my pm with my diagram about the battery, i get my wires/battery terminals etc etc from knu tomorrow and want to get that bitch hooked up asap!
#104
#105
only 2500rms, emps got 5k and spun has 3200
and yea i want to tune my box to around 32 hz, i pretty much just listen to rap and songs that hit loooow so 32 should be good
#107
Hey what size was that torx bit to get the seat belt piece off again?
Was 50, or 55.
Brickloaf- I pretty much well max out at 3000+ give or take (without bench testing the amp its hard to tell, even amps of the same model will vary in there final output) .However when PSAmag tested the 09 T2500-1 it produced a little over 3000w @1ohm with 13.8v . So along those lines all things being equal its safe to say the T4000-1 will produce in the range of 5000w @ 1ohm , now here's the little thing that goes unnoticed, with 13.8 volts
With a 16-18 volt setup like Emp is running the amp has the ability to produce so much more, I can only take a est. guess and say somewhere in the mid to high 6000w range. The problems emp has are 1- Can his subs handle that kind of power, and 2 - the T-2500 had a massive power draw, a quote from the magazine "the maximum current demands of this powerhouse were 310 amps!" So I can only imagine what the draw on the T-4000 must be like.
I don't really feel sorry for him though, these are problems I only wish I had
In a very uncharacteristic like move Emp is just being modist by saying 5000w
Was 50, or 55.
#113
Damn... had to pour a bit of my drink on the ground when I saw those poor art series amps.
RIP Art series!
guess at least it wasnt some of the old RCA Orions or a Mcintosh or anything like that.
RIP Art series!
