should I...
should I...
ok i still got the stock sound system with pioneer which has the 10in sub. well i want just a lil more punch so i was thinking about upgrading my sub to a pioneer 10in 1000w sub... IF i do this do i need to get an amp?? or keep the one i got and just hook my new sub up??
i need some advice thanks
Vtec Rep
if u really want a difference, yes you will need a higher output amp. its like bolting an engine but keeping the same injector size. it will be a little more loud and clear but your putting out the same power
nope the amp is a 6 channel amp underneath the dash (to the left of the steering column)
are u mainly just worried about space or? price?
the best space conscious approach i would do is the kenwood kfc-xw1000 in the stock box and the arc audio KS 125.2 mini in the wheel well (i'm pretty sure it will fit even with the spare but idk for sure)
right right... well the knewood shallow is probably the best one ive had experiance with personally that woudl work in our stock box and anything thats 200-250w rms will work great for it. the arc audio mini amps are good but pricey but thats probably going to be the only one u can hide so its not seen at all. Theres several others in small packages that will fit on the back of the seat or something and only take up 2" or so of actual trunk space
