should i baffle my rear deck speakers
wondering if i should baffle my rear deck speakers, or if it would even be worth it. As mentioned in a post earlier i have an fi btl running 2500 rms coming soon and i'm worried that the pressure from the trunk might **** with the phase or operation of the rear deck 6.5s" i'm putting in (with the 6x9 adapter ofc)....if this isn't a good idea what would be?
JJ i KNOW you've had beastly ass **** in your car before...do you baffle your speakers? just wondering what solution you use/used. I'm finally crackin down on my building my new system.
if my back speakers are infinitys and the two way broke off from the previous owner. will i really notice a difference if i replace them with another low end aftermarket thats in the normal 75 to 150 range? i think it sounds alright now. im gonna baffle them and cancel the high end setup cause i dont need it. ill do a better sub and amp combo
what model of infinity? If its a coaxial i'm pretty sure you'd hear a difference unless you have some big beat in the back.
anyways, JJ, would a little fiberglass enclosure be better? I already bought some baffles, but i can return them if fiberglass pods would be better.
DANRICKARD
10-01-2015 12:08 AM
Delta coupe
09-30-2015 08:11 AM
