soldering ground terminal ring to chassis?
good idea or bad?
dont really want to drill any holes and cant find any good spots that already have a screw (amp is on back of rear seats with 2 ft of ground)
He is right
Your ground can as short as possible but if your using a shitty ground location it is not going to matter how long it is, it just won't work right.
In the end the ground spot and the wire length should be a good blend. Find a good ground spot, then find a place to mount the amp within a reasonable distance.
The problem is it doesn't always work like that. However ground location should never be sacrificed for ground length, it defeats the whole idea.
Brickloaf- Are you getting any whine through your speakers?
If not I think you may be over thinking the whole ground thing, if the stereo is working good as it is then just enjoy it...."If it aint broke don't fix it"
to sorta back it up the whole reason for the question is due to him upgrading to knu 1/0 wire for his T10001BD and he only bought 2ft of wire for the ground.
In cobalts im pretty positive that grounding straight to the battery is the best option but as stated above he doesn't have said option. But if he can get a good ground he should still be fine
the problem with the seat bracket ground is the fact your using only the bolt to transfer all that power. If you have the ring terminal on top of the bracket its sitting on a painted piece of metal that's not attached to the car. so the ground isn't ring terminal to metal held in by screws but solely the bolt itself
Ultimately it will work but you will need to realize that its the 3rd best choice in a cobalt. every car has a different situation and due to the removable bracket in the cobalt it makes it much worse of an option to use the seatbelt bolt. Also realize how much power your running.
There is another option you know
Its right in that whole area and kinda a bitch to get at but there are 2 more bolts that hold the back seats in that are a few inches under the the seat (from the trunk) and have no bracket to get in the way. If you do use this make sure not to put the bolt through the hook that is attached to the seat when you re install it
You could also just go down to your local shop and get them to hack you a bigger piece off the roll it shouldn't cost too much
I miss my civic that had the bolts that held the shocks in at the top exposed like it is in the front of the Cobalts
