Someone that knows more about audio than me.
Ok I hooked up my KICKER ZX1000.1 bout a year old got everything ready to turn on. Turned on the key and the amp turns on, then clicks then gose off, then clicks again and comes on, ect ect. it continues this wehn power is applied and i dunno what the problem is i emailed kicker but i figured i would check on here in the mean time. any ideas?
they havent got back to me yet? its got the thermal protection thing on it, I wonder if thats malfunctioning and causeing it to kick on and off??
sorry i was trying to short hand i guess.
i had the same thing happen to me with my kicker amp in my old car. it just ended up being a fuse though, hope you have the same problem because they're pretty cheap
i rewrote it
I looked up the manual for this amp and infact it does say you need a fuse inline for the amp to run, it actually says you need 2 one 18" away from the amp and of course one 18" away from the batt. There is no internal fuse
http://www.kicker.com/06/tech-suppor...0e01%20web.pdf
I think your problem might be the settings for the input mode. Are you running it set at low or high, and as for the automatic turn on setting what have you got that set at. Also how is it hooked up, do you have an aftermarket deck with a remote wirea nd RCA's or are you running an LOC and a fuse tap?
okay, this might seem silly, but if you ran the wires nicely and its under the carpet, make sure you got the ground in the ground, and the 12v+ in the 12v+, then electrical tape the ends until you got about 1/4 of an inch open, stick it in and tightening it down to make sure no shorts
then check the power to turn it, on, then the power 12v+, then make sure you have a proper ground
Same thing happend to my brother when Circuit city did his install. They broke the connection on the inside of the amp going to the RCA's and it would short out like that for no reason. They ended up buying him a new one.
i dont see a fuse on the amp i guess its internal. the manual doesnt say anything bout a amp fuse just the inline fuse in the power. in witch come to think of it blew already and i replaced it. i wonder if the amp drew to much current and its damaged someway. i mean ive only had it a year thats why im wondering all this. it was working when i took it out of the last car.
No fuse on the amp what size amp and what size power and ground are you running. If you have to big of wires your amp is pulling to much current. But if your power and ground are 2 different sizes then you could pull to much in and not enough out.
I have 2400 watt Fosegate with OT gauge wiring on both ends and a 250AMP inline fuse with 4 25amp fuses on the amp
i have a 600 watt pioneer im ganan hook it up today and see if it work if it does then its most likly the amp.
