sound deading opinions
the damplifier and firewall will be thin and fit no problem the MMP is quite a bit thicker in comparison but actually not that bad and pretty compressable. THe only real disadvantage is the firewall spray needs some time to dry so depending on how quick you wanted to get it in that may put a thorn in the whole deal... also the firewall is the best thermal agent so the MMP and damplifier will very much aid it in keeping you cool you couldnt really leave it out. Oh ya just as an fyi youll see both damplifier and damplifer pro. the pro is thicker but since your main goal is heat reduction you wouldnt see much if any gain with the pro over the damplifer
check out secondskinaudio.com
They also have a very informative forum if you have any questions or what not. There's also a chart for drying times on the forum if u wanted to check it out
I figured they wouldn't be too awfully thick. What is best to spray Firewall? The device they sell?
You've been much more helpful than you know, and it's greatly appreciated.
to spray it yes you would need to buy their spray gun.... it is some thick ass stuff and as i learned you can only water it down so much but you dont have to spray it. I actually have said gun but i've never used it... all the stuff ive used in my car i've painted on with a brush
importkiller
09-30-2015 07:18 PM
