speaker help
speaker help
Alright did some searching of old threads and maybe I'm just easily confused.
All I want to do is replace the front speakers, and keep the tweeters Is pretty much anything better then stock? Want to spend around $100 or less.
Have the ddx-712 Headunit. Still using the stock amp to power all the other speakers.
What I did learn is that if I'm keeping the tweeters and not going to use an aftermarket amp then I should be looking for a pair of coax speakers. What I'm not sure of is how many ohms the speakers should be. Most on crutchfield are 4. That ok?
So basically all I want to do is take out the door speakers and install another pair that will sound better. Going for simplicity here haha.
Throw up some links of any recommendations if you want.
Just to get me in the right direction. Will these work?
http://www.crutchfield.com/p_065S65R...5RC.html?tp=95
You will loose half of the power on those front speakers by going to a 4ohm speaker. Not allot you can do about it as 99% of the speakers are going to be 4 ohm. The speakers will work they just wont get as loud as your used to.
Ultimately when you get into these premium type systems I find it best to just gut them and start fresh but thats just me.
Ok so compared to the stock fronts, how much quieter are the Kappas going to be? If they are going to be similar in volume but noticeably better sound quality then I will go with them. If they are alot quieter then I will just buy another stock speaker and throw it in. I like loud music.
Are there any 2 ohm speakers you guys know about? I don't mind spending the money if I have to. I just would of preferred to spend around $100. In the springtime the Chevelle gets the money and the Cobalt takes a back seat...
Just came across this thread while doing a search for 2 ohm speakers.
Emperor, you mat be interested in posts #3 and #16 in this thread. Why do their opinions differ from yours?
http://www.diymobileaudio.com/forum/...-speakers.html
And out of these speakers...
http://www.sonicelectronix.com/viewc..._id=47&f_31=97
Which ones you like?
well if your budget is 99 then JBL GTO628 (GTO-628)
fyi JBL and infinity are made by the same company so they are virtually the same with just different cosmetics.
the reasons why their opinions differ is because i base alot of my opinion on what ive herd and what ive done not necessarily what is supposed to happen in theory. They are correct in saying a 4 ohm speaker can get louder then a 2 ohm, as a 4 cylinder car can be faster then a 6 cylinder. The thing is i have a cobalt that had the pioneer system and i did a straight swap from the factory speakers (not blown) to a very nice set of 4 ohms (i think i spent 250 on the speakers) and they sounded much much better but didn't get as loud (i at first left the rear speakers and i had to fade to the front a few notches) So yes you can get 4 ohm speakers but if your goal is louder why would u start off at half power? Also you have to remember that alot of the DIY speakers have a higher efficiency over normal car audio speakers. Ive also done a few different cars with 2 ohm speakers and had the same effect. In the end thou if you really really want a 4 ohm speaker then get it and run wires straight to the deck. You can leave the stock tweeter if you want or disconnect it
Is that your thread thou? a few things didn't seem to match up with what is going on in the cobalt pioneer system.
I was definitely going with your advice regardless of what the people in that other thread were saying. You have a cobalt. You've done different configurations of setups in your cobalt. ect. ect. That trumps some technical BS about why a 4ohm speaker, in theory, should be the same as a 2ohm haha.
If this were two years ago then my budget would be much higher and I would get a 4 channel and amp all of the speakers in my car. Truth is I don't know how long I will have the cobalt for so I don't want to put too much money and effort setting up a system I wont enjoy for years to come.
sorry to be a pain. Are these worth the extra money over the jbl gto628 you listed in your above quote? I'm Looking at ebay and they are going for less then $150.
http://www.sonicelectronix.com/item_12266_JBL-P662.html
Or
The first link are shallow mount speakers. The second link are normal. Guess the shallow mounts require less power. What you think?
not a problem dude i come on the forum not because i have to but because when i bought this car i didnt know anything. and most i learned was trial and error on my own car (and believe me ive had plenty of error that i never posted on the forum)
can u post both links again. both of the ones u put up were to the same speaker
JBL P662s 6-1/2" Shallow-Mount 2-way Power Series Speakers
and regular
JBL P662 6-1/2" 2-way Power Series Speakers - Sonic Electronix
There is an auction ending for the shallow mounts, but I can get the other ones for about $85. So whichever you suggest outta the two is what I'll get.
I have an 07 SS Supercharged.
I'm probably going to go with these - no need for coaxial with the tweeter already in the door:
Amazon.com: Infinity Reference 6030cs 6.5-Inch 270-Watt Two-Way Component System: Car Electronics
Keep the tweeters as a spare in case the Pioneers blow and wire the speaker directly since the factoru amp already takes care of the crossover issue. wooooo
mmm if u do that id yank the stock tweet and install the whole component all together. i mean u can just do the woofer but id do the whole shebang. But if u do install it like that and ever do put the infinity tweets in id run the crossovers off the woofer wiring and leave the stock tweet wiring just hanging basiclly
brickloaf
09-25-2015 09:10 PM
