Speakers not working with new head unit
im installing my alpine 9886 today and i have it all wired up correctly according to the diagram and everything, but im not getting any sound.
the system turns on and everything fine, i can switch sources, etc. but no sound comes out of the speakers...
any advice?
also, how do i install the steering wheel control thing?
best buy watend 150$ to do everything so i thought id do it myself, but ive only done like one other install before.
any advice?
are you using the wiring connector? cuz a buddy of mine told me that its possible that some of the connectors are messed up and if you get the cheap one that no sound would happen due to the stock amp.
so what should i do? get a new harness? my brother might have an extra amp i can use...would that help at all?
If your car has the seperate amp it needs low level inputs. I hope you didn't wire the Head unit's internal amp speaker outputs to it.
The wheel control depends I guess on the unit you purchased. Looking at the pinout of the 24 pin connector; depending on your car it appears to be either pin B3, a light green wire; or pin A9, a dark blue wire.
As said before there is a pink "radio on" wire that is essentially an amp on wire when used with an aftermarket HU. There should be an "antenna power" wire on the new HU that you can use to connect to that pink one on the stock harness.
oh ****. yes i do have the 7 speaker pioneer system. im a complete n00b with this stuff lol thanks for the help. so i need to connect the antenna power wire to something?
any advice?
any advice?
i did the blue to blue white and it works great!! it sounds soooo good, but i was hoping i could bypass the bass to just the sub like alpine says i could. anyone know how i could do that?
when i change the subwoofer setting, nothing happens. i have the 7 speaker pioneer stock system...will it work with that?
Please Help Me!!!!!!!!!!!!!!!!!!!
I Have the same Problem I even did the blue wire from the HU to the Blue/white on the Harness end. Lights up works but no sound. And how do I turn on the factory amp Which wire is it and how is it done? And one more thing anybody know how to get it out of there!!! Please Help Me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
if you got the steering wheel control adapter and didn't get it working yet. Don't follow the guide they mailed with the parts. Go to their website. They have car specific guidlines and much more well written instructions for it... It's what i used, and helped a hell of alot....
If there is a way to turn off the sub settings and preamp that would be good; to make sure it is outputing true fullrange to the amp. The only thing you can do to change the sound is mess with the EQ on the Head unit.
I'm jumping on the "no sound" bandwagon with my new Alpine IVA-W205. What baffles me, is that my pioneer Screen in it before this one, worked fine, with no special wiring required....that i know of. I think we'll have to try some of these solutions you guys posted.
