speed sensor wire
VSS wire is on the trans. I'll get you guys the color and location when I'm at the shop on monday...
Next time I get the car in the air I'll try and get a pic of the connector as well
The radio does not have a speed input, it has a GMLAN signal that adjusts the radio volume at different vehicle speeds, if you need a speed signal input you will have to get it from the transmission speed sensor. I believe it will be a yellow wire at the speed sensor on the manual and automatic transmission. Hope this is helpful.
You can tap into it behind the dash gauges in the car. Thats what I did. Some people will say it makes no difference. But when I had my unhooked there were times I would get inaccurate readings just going on the GPS
I'll have to look into it more once the car gets back to my main shop. I suspect I'll go to a wheel speed sensor instead.. I've had a couple sources tell me the VSS at the trans, and a couple more tell me the wheel speed sensor.....
Hold off on this one. On my drive down to our other shop for more work on the car the speedo was not working. With the deck disconnected the speedo works again.
please help... im hooking up a pioneer d3 and need to hopp up VSS aka speed sense wire...
i know its not 100% needed but i would liek to for more accurate signal, this is huge when i do lose the signal cuz itll still know im moving
where is the vss located ive herd its a yellow wire underneath the steering wheel is this correct?
also something abou the cluster? please help!!!
yellow wires under the steering wheel are airbag wires! they are usually in yellow protection with yellow connectors! do not touch them unless you un-arm the airbags!
