starting to get a sound system put together
Old 06-29-2012, 07:20 PM
CobaltItaliano's Avatar
All right for all the audio experts on here, I am starting to piece together and build a sound system for my 07 cobalt coupe. As of now I have a kenwood double din, rockford fosgate 6.5 round front speakers, and rockford 6x9 rear speakers.
Looking to get a dual 12 subwoofer setup. Trying to figure out best bang for the buck, as well as deep bass.
I do not want a complete overpowering system that the "gangsta" kids have that u can here from a mile away, but just want a decent thumping system that turns heads.
A friend of mine has a 1000 watt system setup right now and its a bit too much for me so im probably looking into a 600-800 watt setup preferably but definitley open to options thru the experts on here.
I want the subs to fit nicely in the trunk without it looking like a misplaced box in the back. Looking for something that fits nice and looks nice, plexiglass over the subs or amp if need be. Obviosly a good setup that allows me to get to the tail lights and battery still. Just looking for help, suggestions, reviews, anything lol
So any help would be great.
Old 06-29-2012, 11:28 PM
Old 06-30-2012, 01:59 AM
Drunkship's Avatar
If you don't want a gangsta setup you honestly don't need two 12" subs. I had one 12" Alpine Type R in my Dodge Neon in HS 5 years ago and my ears are still fucked up to this day because of it. Get one 12". Hell, even a 10" would be fine.
Old 06-30-2012, 02:20 AM
ive had 2 10s that pushed 600 watts in the past and was pretty quiet. id rather have the 2 12s. thanks for the reply
Old 06-30-2012, 02:43 AM
cobaltss#01's Avatar
I have a 12" rockford fosgate power sub hooked up to a jl audio 500/1 and it was pushing 136.8 db. and it still had more to go.
Old 06-30-2012, 03:40 AM
EmperorJJ1's Avatar
first off when u say watts are u referring to peak or RMS. also most people fail to understand that power doesnt directly equal sound. just like HP doesnt direcly = speed. example 18 wheeler vs LS1 crx.
Old 06-30-2012, 01:51 PM
my bad im looking for rms. Still doing tons of research. I would prefer brand names like rockford fosgate, pioneer, etc. so im basically looking for an amp in the 1200-1800 range that will power the subs and get a total system wattage of around 800-1200
Old 06-30-2012, 04:46 PM
EmperorJJ1's Avatar
right well a 1200w sub in the right box should get pretty loud
Old 06-30-2012, 04:54 PM
empjj- you seem to be the expert on here on audio, so how does dual sundown audio subs (400 watt rms each) they come in 2 ohm or 4 ohm 10 inch or 12 inch (dont know which size would fit better?)
and a aq1200d amp?
Sundown Audio E10 D2
AQ1200D Amplifier
Old 07-01-2012, 05:55 AM
EmperorJJ1's Avatar
sure are u planning on running the amp on the 800w @2 ohm? i wouldnt run it at 1 ohm with those subs
Old 07-01-2012, 11:38 AM
Well I know now I am going with the 10 inch sundown e series (rated at 400 watts rms)
with that aq1200d aq series amp. (rated at 1200 watts rms).
The subs come in either 2 ohm or 4ohm (I'm guessing 4 ohm since I am getting a pair?)
Then how would I run that to get the most out of the subs since the amp is rated at 1200?
Old 07-01-2012, 03:56 PM
EmperorJJ1's Avatar
at 1 ohm would get full pwoer from the amp. ud also probably blow the subs since ud be giving them what a 3rd more power then they are rated. i mean u can do it seeing as ive done worse but u have to be really careful and know what ur doing
dual 4 will get u 1 ohm dual 2 will get u 2 ohm with a pair
Old 07-01-2012, 08:36 PM
I dont want the full use of the amp. just the full use of the subs. So 800 watts total (since they are 400 watts a piece) is it possible too hook it up that way or will it be difficult? im pretty noob to this lol
Old 07-02-2012, 02:35 AM
EmperorJJ1's Avatar
ok in that case wired at 2 ohms would be a perfect match for those subs
Old 07-02-2012, 02:49 AM
ROB517's Avatar
I wouldnt go with that amp personally but if you do I would do dual 4ohm subs that way if you need/want the power you have it. You can always turn down the power on the amp.
Old 07-02-2012, 11:07 PM
I value a good opinion. Why would u not go with that amp?
Old 07-02-2012, 11:11 PM
So my best bet is to just get the dual 2 ohm subs and wire them to be a 2 ohm load at the amp? Here are the amp specs:
Specifications
Model AQ1200D
Frequency Response 20Hz—250Hz
Signal to Noise Ratio 100db
Low Pass Crossover 24db / Oct
Low Pass Crossover Range 20Hz—200Hz
Subsonic Crossover Range 10Hz—50Hz
Input Sensitivity 0.2V—8V
Output Master / Input Slave Connection Yes
Working Voltage 8V---16V
Efficiency @ 4 ohm 84%
Damping Factor Less than 150
Fuse Rating 40Amp X 3 (Linked 240 Amp)
Output Power 14.4V @ 1% THD 510X1 @ 4 ohm,870X1 @ 2 ohm,1200X1 @1 ohm
Output Power 14.4V @ 5% THD 1470X1 @ 1 ohm
Dimensions 12.75"(L)x9.27"(W)x2.35"(H)
Old 07-02-2012, 11:13 PM
Keep in mind this would be my setup. I will never upgrade it with this equipment, meaning I will never get a different amp for those subs, if I ever upgrade I will only get different equipment. Basically, I will not change the setup on this equipment.
Also does anybody know anybody who would build a custom box?
Last edited by CobaltItaliano; 07-02-2012 at 11:13 PM. Reason: Automerged Doublepost
Old 07-03-2012, 12:56 AM
EmperorJJ1's Avatar
running that amp with those subs might not be the most cost effective but to be honest at 2ohms ull get cleaner sound and u wont have to worry about running the amp all crazy bc it will only get to 2/3 potential. MIND YOU that doesnt mean you can crank the gain and all the knobs and not worry about it
Old 07-03-2012, 01:54 AM
Is there another amp with similar build quality and reliability you reccomend?
I am not fully set on that amp, just been on some other car audio forums and talked with experts that know alot more crap than I do and they reccomended that one out of reliability and potential. I just want a decent amp that I can run without having and present or future problems
Old 07-03-2012, 02:37 AM
EmperorJJ1's Avatar
fyi most amp problems are user error due to shitty install, bad presets, blown subs, general user stupidity ect
running that amp like ur planning is "odd" but to be honest its not a bad idea or anything id say not to do. just most people dont.
Old 07-03-2012, 03:12 AM
right, but are there better or similar less costly alternatives that have similar capabilities?
Old 07-03-2012, 03:43 AM
EmperorJJ1's Avatar
im sure there are but im being lazy atm
Old 07-03-2012, 10:02 AM
tomj77's Avatar
U sure those were set up right cause Iv ha 2 tens, and crappy Sony ones and they pounded hard and loud. But then again, how's ur hearing lol
Old 07-03-2012, 12:35 PM
Yeah I bought used Orions and thats why Im sure they sucked a**. Im actually going with 2 10s now since they seem to fit trunk space better
Quick Reply: starting to get a sound system put together
