Steering wheel controls adapted to aftermarket radio???
^LOL New guy already knows about Cobe..No worrys man...Dont become a Cobe and you'll do just fine ..I wasnt tryin to flame you also..It just seems in the past week we've had a few of these posts lol
yes. i have along with a few other members. the best company to go with is PAC Audio. ive herd good things about metra too but one member on here was having trouble with his and ive never used the metra steering wheel control adapters myself so idk
what aftermarket radio do you have? as long as it has a steering wheel remote input then u should be good but the wireless ones are suck
Car Audio Stereo - Car Subwoofers - Car Amplifiers and Speakers
That's where I got my stuff and they seemed to beat all the prices I could find locally.
Can some one post a brand and part number of an interface known to work 100%.
I read threads that a person used and adapter and just volume works, or only the seek button works.
I want to be sure the interface I buy works for everything otherwise its just not worth it to me to install my radio.
the only real possibility for anything other than it is what it is is a bad soldering joint on the data wire connection. which is possible because i don't do perfect soldering.
but very rarely has this happened where none of the steering wheel controls work (i don't remember ever but im sure it has happened and i forgot) i use volume up and down and track up and down the most followed by mute every once in awhile. and when this normally happens if it does is when im trying to change volume and track at the same time or one right after the other. and when it does most times it effects changing tracks, i can still change the volume, mute, source change and whatever the other button is if there is one.
