Steering Wheel Controls (PAC SWI-PS)
Old 09-12-2013, 10:31 AM
blueLNFftw's Avatar
I have my radio harness mated to my female OEM connect harness. Between them I have added a micro bypass to disable the e-brake monitoring. I am tapping the new ACC wire from the sunroof fuse inside the car (my car has no sunroof but there is still a fuse these so win)[new radio will function like stock with keys out].
My ACC wire will connect from the fuse > to my head unit, the PAC unit, and the black/white wire on the OEM SWC harness.
Green wire on the PAC unit will connect to the blue wire on the OEM SWC harness.
I have my grounds all together tied to the stock OEM harness plug and I drew another lead from the ground to attach to the frame of the dash some where.
Im waiting on my SVX2001v SirrusXM unit and I will be installing this all into my car on a AVH-x5500BHS. I have the S video cord to use all of the advanced app features. I have been taking pics along the way of building the harness because I am going to compile a write up specifically for an 06 SS with OEM Pioneer and no OnStar. Plus the PAC info is scattered on here so I would like to get it all in one write up for others to see and use.
Old 09-12-2013, 10:30 PM
blueLNFftw's Avatar
anyone
Old 09-13-2013, 06:43 AM
EmperorJJ1's Avatar
Pioneer AVH-x5500bhs
PAC SWI-PS
I have it all wired on my desk and understand how to hook up the wiring, however, will I still need to plug the 3.5mm jack into the back of the HU?
yes you do to the WR input
Old 09-13-2013, 10:49 AM
blueLNFftw's Avatar
Thank you.
I see the port on the HU now, makes more sense.
Its all going in today.
Old 09-14-2013, 01:06 PM
blueLNFftw's Avatar
Okay, so its all in but now that the stock radio is out the DOOR OPEN feature do not work in the car.
When I take the key out the windows dont stay active nor does the radio stay on. How do I get that back?
Tapped ACC from the sunroof spot.
Old 09-14-2013, 01:15 PM
EmperorJJ1's Avatar
tapping acc shouldnt mess with the windows or anything else. so the windows used to roll down until the door opened but now dont?
Old 09-14-2013, 04:37 PM
blueLNFftw's Avatar
I figured it out, kinda of.
The car off feature stopped working after two cycles while I was installing. Well I had to leave mid install and it worked again when I got to the store (no radio in the car at all). Came back home and it stopped again. Basically, what I have learned is that you can only cycle on and off to keep the radio on twice without actually starting the car and moving it fast enough to engage the power locks.
Its all in, looks amazin, works great.
Only have to work on this dumb SWI-PC. **** wont program right. Gave up for now but mounted it where I can get to it easy to finish dicking around with it later.
Only volume up and seek up work.
Volume down mutes
Seek down down the programmed stations change
Source actives bluetooth
Old 09-14-2013, 05:08 PM
EmperorJJ1's Avatar
hmm when doing the programming did you skip the controls we don't have or program them with a different button?
Old 09-15-2013, 12:15 AM
blueLNFftw's Avatar
Tried to skip the ones we didnt have.
I think I may try going through the whole process and programming every one our cars dont have to the 1-6 button since I dont care if it doesnt work.
05-28-2022 03:47 AM
Solaris99
28
03-15-2017 01:22 PM
ineedacobaltss
11-07-2015 02:25 PM
TedSS
26
10-10-2015 04:30 PM
09-26-2015 06:44 PM
Quick Reply: Steering Wheel Controls (PAC SWI-PS)
