stock sub modification
Ok, first of all, how d you remove the woofer from the enclosure? Do I have to remove the one bolt off the back? I already have the enclosure out of the car. Also, can I hook this sub up to my mono amp? It is a 2-ohm amp. Thanks
Ok i got it out of the box. can i hook it up to my amp?
Anybody???
Anybody???
1st of all..If you hook up your 2ohm amp you WILL blow the sub..its a 4 ohm sub, 2nd of all...You do need to remove the bolt out of the back in order to take it out
My amp is 4ohm but it can put more power out at 2ohm. Its a JL e1800d. So if the sub is 4ohm and my amp is 4 ohm, how do I hook up the new wires?
wow man...not to be mean rude or anything but if you dont know how to even hook up the wires on the sub i wouldnt touch it...A volt meter will be your best freind and wiring digrams on google will be as well
For this setup....series..remember with ohms its all what the amp see's
and parrell will drop everything to 2 ohms if bridged
