Stock Sub Replaced with Polk MM1040
Old 05-03-2012, 04:46 PM
Prestige_Worldwide's Avatar
So how should I secure the MDF ring to the box using screws or glue and them the permatex?
My sub is a little to deep so I have a 3/4" spacer I need to glue/screw onto the box.
Old 05-03-2012, 04:52 PM
toysareforboys's Avatar
If your bolt pattern for the new sub is the same as the factory one, I would use really long screws, lots of permatex on the ring of the factory sub box, and screw the sub and mdf ring right to the box as one piece, right into the factory screw locations
If your new speaker is a different pattern, just permatex and screw the MDF ring to the enclosure, make sure to countersink the screws. Then just screw your new sub to the MDF ring (permatex if you want too).
-Jamie M.
Old 05-03-2012, 05:01 PM
Thanks, I will have to pull it out this weekend and see how the holes line up with the new one.
Old 05-03-2012, 09:06 PM
EmperorJJ1's Avatar
you do realize rtv is silicone so it has the same potential effect
05-28-2022 03:47 AM
bigdeertz
11-17-2016 09:41 AM
10-21-2015 11:57 PM
DANRICKARD
10-01-2015 12:08 AM
09-27-2015 08:53 PM
Quick Reply: Stock Sub Replaced with Polk MM1040
