Stock subwoofer information needed
I am considering replacing the factory subwoofer with an aftermarket subwoofer and re-using the factory housing....
Does anyone know the mounting depth of the factory subwoofer?
Does anyone know the air volume for the stock enclosure....
I know I can measure them myself, but I didn't want to break the seal on the factory sub until I am sure that I will have something to replace it with....
Any help will be greatly appreciated...
Thanks...I found the mounting depth, but the volume was a different matter...
I am going with an elemental designs shallow depth and I just needed to ensure that it doesn't sound like crap....
Thats their only sub that will fit the box, I tried fitting a k series but the motor is too big.. but they could probably make a spacer for you and make it work
I upgraded mine using a 10" Pioneer shallow mount. Had to make the opening a lil bigger but it fits. Even kept the stock grille on, looks factory but sounds way better.
Well .3 cu sounded a little small so we actually measured it.... The stock sub enclosure is actually .58 cu ...just something to keep in mind when exchanging subs....
Btw...the box is actually a pretty solid box...water tight...not a bad deal to keep after all
You can determine the volume with something other than water, but then you will need to incorporate a packing efficiency into you calculation along with the component's density...
camaromanss1992
10-01-2015 10:51 PM
jcalvin1126
09-11-2015 10:24 AM
