sub trouble
sub trouble
Ok, so with help from people here i was able to get my system going. Long story short i took the sub out...it was just to big. I decided to get a smaller setup. I went to reinstall my am and now it wont even turn on, checked fuses on the amp all 30amp fuses are fine. redid the power wire, re did the ground. I put the ground on the stock ground by the battery, dont know if that is good or not but it worked once before and now...nothing. I got and add a fuse and used that in the wiper spot, the wipers work but the amp will not turn on.
Any clues?
Any clues?
