subs
yes it is possible regardless. You have to get a line out converter so you can have rca outputs and you will need to rig up a remote wire for your amp by running a wire to the fuse box that will shut off with the car...
https://www.cobaltss.net/gallery/sho...searchid=11202
here is want you need... minus the capacitor... and the crossover is optional jus need an line out converter like ranger said...
this is jus how i had mine setup
very nice. thanks alot that will make things easyier
is there a cretin type of line out converter that i need?
its a box with rcas on one side and 4 wires on the other... rear right speaker ( + - ) and rear left speaker ( + - )... no bigger than a credit card in size... thicker but not bigger...
http://www.sjgreatdeals.com/sisloc80.html
