Subs pulsing.... Weird... help
well im hoping this sub thing will be fixed with this ground loop isolator. im tired of the pulses everytime i roll my windows up and down.
no... get a piece of wire and touch the rca shield to the chassis of the radio. all ur problems will be solved. You need to somehow make that permanent (normally at the shop we will solder one end on a set of rcas not being used and the other on the radio chassis or pop off a screw and ground it with a ring terminal
http://www.icixsound.com/vb/showthre...7&page=1&pp=10
