Subs with stock head unit
ok ive been reading up on this and i just want to know if i got this right
i have an 07 ss. and im wanting to install 2 12s and a 750 watt amp
so i can run power and ground right there in the trunk.
but then i need the line out converter to tap into the rear speaker wires for the rca?
and how do i tap into the remote cable from the stock sub? or do i have to run a new remote wire?
basicly im wanting to find a really good how to on this and i havent found one for the ss. just for the ls version so they dont have the amp and sub
thanks
thanks
thanks
thanks
the one i had plugged directly into the fuse and split the connection out, the easiest way would just use fuse taps from autozone, they slide onto the fuse (wipe one is the one u wanna use) and leave a little prong sticking out when u plug it in so u can tap into it
ok i need some help now!??!?!?
i hooked all this up and all my original speakers work and everything but the subs dont work.
i used power and ground located in trunk
for the remote i used the fuse that said it was for the amp. it is the only 20 fuse
and i used the loc thing. the amp has a light that is lighting up and staying light even when the car is off?
what am i donig wrong here?
read>me
i hooked it up to the wiper after i did that wrong
but still no luck
then i did some snooping on here and found that some of the wiring for those locs are kinda silly so i messed with it and figured it out. thanks for all the helpful responses
but still no luck
agentirons
10-16-2015 02:11 AM
