Subwoofer box Disected - make your stock steath box boom.
Kicker 40CWRT101 CompRT shallow-mount 10" subwoofer with dual 1-ohm voice coils at Crutchfield.com
Oh you are talking about the guys picture just above, nevermind.
that's a nice set up burner.
I was thinking of doing this but then did this
[IMG]http://i1232.photobucket.com/albums/ff364/05cobaltsssc/IMG_20130531_171811_642.jpg[IMG]
[IMG]http://i1232.photobucket.com/albums/ff364/05cobaltsssc/IMG_20130531_171755_847-1.jpg[IMG]
its a 0.8 cft mdf box with a shallow mount kicker 10" (cant remember the model) and my old fosgate 500w 2 channel amp
no they came out with a brand new series in Jan 2013 at CES called the RT. They are bad with 600 watt rms handling and very thin.
#37
Best fit for the enclosure is what it comes down to. Although I desire that audio utopia my car is setup with a big exhuaust, trubo, etc. Its too noisy a platform for sq.
To the SD's defense, the paper cone is to my liking, mainly due to its pulp paper has one of the best weight to strength ratios of any common material used on speaker cones. It may not blend as well but it will definitely cover the low end with authority and have strength against the high pressures of a small enclosure.
The SD and my Clarion setup for daily driver duty will be more than enough for loud bass in a small space.
#38
Here is my favorite amplifier 850 watts rms at 2/1 ohm. It has ARC audio GH architecture. Amp requires a 90 amp fuse.
The plug and harness from the car are wired and soldered together to make a quick install.
The power and other stuff was run tonight. All OFC 4 guage raptor cable. Crimped some connectors and bolted it all up. I still need to run a remote turn on lead and get the subwoofer installed. Still debating if my sub choices are going to be enough for my amp. I want to really get the most bass in a small space. Thinking of going a little different route but still using the stock box.
#39
here is a review of my amp. Mind you I got this 600 dollar amp brand new from a distributor (i have a tax exempt code for dealing car audio) for 125 bucks shipped with a warranty. :P
http://www.pasmag.com/car-audio/repo...plifier-review
#40
#41
Okay so you got my interest why is clarion your favorite amp? Yes 90amp fuse is required for 900 RMS. Weird it does say 1 Ohm stable in Mono mode but no rating for it. Really clean power from your experience or just got a good deal on it or what? $230 is a little on the high end for mid brand 900 RMS.
#43
Okay so you got my interest why is clarion your favorite amp? Yes 90amp fuse is required for 900 RMS. Weird it does say 1 Ohm stable in Mono mode but no rating for it. Really clean power from your experience or just got a good deal on it or what? $230 is a little on the high end for mid brand 900 RMS. Amazon.com: Clarion XH7110 850 Watt Mono Amplifier: Car Electronics
#44
Cool ya $125 is good deal for 850-900 RMS. I'd go with it too for that price if thats the power I was wanting to run. It's got the fuse rating to put out the rated power and its CEA certified. I would just be a little concered for running 1ohm. It says it is 1 ohm stable but no rating for it is a little weird.
#45
#48
