tail light, headlight, blinker, fog light wiring diagram
so basicly i need to have a buttion that turns off and disables all of my outside lights, tail light, break light, blinkers, fogs ext. all in one touch of a single buttion. does any1 have a wiring diagram for these? or atleast know the color of the power running to all of these. my side markers are allready taken care of i just need all the lights in the front and back. thanks
1 Post
Brake lights are easy, just blow a fuse then use the blown fuse as a way to put a switch in (You'll have to wrap the wire around one blade, put it to the switch, a fuse holder, then put the end of the wire around the other blade and plug it in. When you need the brake lights killed (So if you hit the brakes they don't light up), just flip the switch to OFF. It basically acts like a switchable fuse in your fuse box.
As far as the other lights, you'll probably just need to crank the stick back to just turn off the autolights. You will need to find a solution for the gauge cluster such as a LED light strip or something. I'm pretty sure if you're killing all of your lights for your "work", you're probably not needing to use the cluster much anyways.
