terrible rattling under car
Old 06-01-2009, 11:50 PM
brickloaf's Avatar
sooo for the first time ever i had the pleasure of seeing my car on the road when im not driving it....my friend was driving and i pulled up next to him and he cranked up the subs and i swear all i could hear is metal smashing against each other underneath the car....
im probably going to take it to a auto repair and see if they can tighten up that **** and put some stuff to keep that **** from happening
has this happened to anyone else?
Old 06-02-2009, 12:04 AM
Spun's Avatar
What side of the car did you pull up on?
You can take it to all the auto shops you want but it won'y help....ahh if only it was that easy.
You want to get rid of it, pick your self up some Dynamat, Hush Mat, Spectrum, ect, ect.
If you were on the passenger side of the car chances are it was the vent in the trunk you herd .
If you haven't done this yet, get some 2 way tape and put it on the back of your lic. plate
Old 06-02-2009, 12:41 AM
brickloaf's Avatar
i could hear it from both sides, sounds like pipes are banging together
and what vent in the trunk?? it was coming from under the car, and i have dynamat behind my license p
Old 06-02-2009, 12:47 AM
EmperorJJ1's Avatar
ya theres alot of **** it could be. localize where u heard the rattling and post it up
and youve already put the second skin on the wheel well?
brickloaf's Avatar
will do, but i think its more than 1 piece rattling
Old 06-02-2009, 12:15 PM
Spun's Avatar
I had a similar problem.
It was under the car where the spare tire well ends at the back it was bordered by some steel ...fins I guess would the best way to describe them. They box inthe spare tirel well.
The well was flexing and banging up against the fins or the other way around. Spray on sound deadner help alot but didn't totally get rid of it.
If you pull the carpet off the passenger side of the trunk you will see a black square shaped plastic and rubber piece along the bottom behind the tire. It is a vent to allow air to escape when you close the doors. I got rid of mine and covered it with Hush Mat and some window screen from Home depot.
I did however cover it right up with Hush Mat when I moved my battery there. I didn't want to take the chance of the battery getting wet.
Now my sunroof pops up a bit when I close the doors, no biggy. So you can cover it if you so please
Old 06-02-2009, 12:42 PM
brickloaf's Avatar
i think I know what your talking about, its close to the passenger side brake light...? on the far right side of the car behind the carpet?
if thats what you were talking about I took the rubber piece out cuz it was slapping up against the plastic vent. if thats not what your talking about I already have my entire wheel well covered in damp pro
Old 06-02-2009, 12:44 PM
G85 SS's Avatar
I will guarantee you it is your heat shield. Check it.
Old 06-02-2009, 01:11 PM
brickloaf's Avatar
unfortunately I have no idea what that is, ill look in to some how-to threads to see if i can find out where its located and see what i can do from there
thanks!
Old 06-02-2009, 01:24 PM
Spun's Avatar
Heat shield
Its a good possiblity.
Its under the car between the exhaust and the car
The always come loose on every car.
If you try to fix it make sure the car has not been on for a while, the exhaust tends to hot and there is little room betwwen the pipe and the shield
Old 06-02-2009, 01:48 PM
brickloaf's Avatar
is it towards the rear of the car by the end of the exhaust pipe, or is it far enough under that ill need to get the car jacked up
Old 06-02-2009, 02:09 PM
G85 SS's Avatar
Yea, you will know what we are talking about if it is loose. On mine both of the rear rivets popped loose so I ghettofied it with some screws. I still get a teeny tiny bit of rattle but nothing like how it was. I am contemplating putting some rubber groments between the heat shield and undercarriage of the car. It's going to be towards the rear of the vehicle. Just follow the exhaust and you will see this aluminum looking shield thing. that is what comes loose.
Old 06-02-2009, 02:14 PM
brickloaf's Avatar
will do! i have a LT btw if that matters?
Old 06-02-2009, 02:16 PM
G85 SS's Avatar
Newp, still has the same shield.
Old 06-02-2009, 02:19 PM
brickloaf's Avatar
Old 06-02-2009, 02:22 PM
domesticdisturbance6's Avatar
yea its probably the heat shield becasue mine rattle loose since i put my subs in my i just took it off.because it got real annoying.
Old 06-02-2009, 03:37 PM
brickloaf's Avatar
yep! it was the heat shield, its basically in the middle of the car so I cant get to it, and even when i do get to it, i wont know how to stop the rattle anyways...
should i take it to a shop and see what they can do?
Old 06-02-2009, 03:39 PM
G85 SS's Avatar
I just took a screw. I found one that was the same size as the hole so that way the threads would catch and secure the heat shield. I don't know what size screw it was that I used.
Old 06-02-2009, 03:42 PM
brickloaf's Avatar
are you sure its cause a screw fell out? or could the subs just rattle the hell out of it even with all the screws?
Old 06-02-2009, 03:43 PM
G85 SS's Avatar
I had mine on the lift a couple days ago changing my downpipe and I checked it again. Still as secure as it was when I put the screw in.
Old 06-02-2009, 03:53 PM
brickloaf's Avatar
this would be alot easier if i had a lift =[
Old 06-02-2009, 03:55 PM
G85 SS's Avatar
Jack the car up from the rear. Shouldn't be too difficult to do that. haha
Old 06-02-2009, 03:56 PM
brickloaf's Avatar
is there any way you can jack up the whole rear end? besides the individual wheels
Old 06-02-2009, 04:39 PM
G85 SS's Avatar
jack stands are your friend. Of those ramps you can drive up on.
Old 06-03-2009, 01:13 AM
EmperorJJ1's Avatar
ya my heat sheild is one of the few rattles i still have un attended
Quick Reply: terrible rattling under car
