Is ther any way to disable RAP? (Retained Accessory Power)?
i have a compustart remote start/ alarm and also an aftermarket HU.. How my remote start works, when i take the key out of the ignition, the car is still on til i get out and close the door.. now since the rap feature thinks the car is still on and i open the door, the radio stays on, even when the car turns off.. is there any way to disable/work around this?
The radio staying on or the RAP feature is all programable with the compustars, yours is just set to default, get the guys who installed it to hook an OP500 (option programer) up to it and fix the problem. They can set the dsoor locks (drivers side priority) and also turn the horn honk on or off, along with whatever other features your alarm has. Thats the great thing about compustarts, you can program them to do so many things. Mine has the option for remote unlock, I can phone in a pin # and the system will unlock my doors, incase I ever lock the keys in the car. However since I need the remote to lock the doors I don't see how this will hapen but still cool to have
When I first got mine we had the problem that when I disarmed the car the radio would turn on and not shut off until I opened the drivers side door, it was a little wierd if I went to the passenger side first (since I can't use the trunk my back seats have to act like it for grocery's and whatnot) by the time I got to the drivers side my stereo would kick in, and if I used the ATT button when I pulled into whatever place I was going then of course it would be cranked up high and scar the sh*t out of me
I'm pretty sure that RAP fuse is vital to the alarm and I think if you pull it, the alarm will not function as it should, same with the remote start
To fix this problem, take it to your installer and have them wire up the "ground out when armed" output from the wiring of the compustar brain and have them tie that wire into your driver side door pin. What happens in this case is once you are out of the vehicle and you close the door(s) the car turns off and is set into "ready mode" and the alarm arms itselfs and locks the vehicle, the compustar at this time during arming will now send a ground pulse to the driver door pin quickly making the car believe that a door is open/then shut and the radio turns off. You can take my word on this that this is the correct way to do this. I have been in the mobile electronics industry for 13 years now.
EDIT: i went down there today and they said they can try it but there might be an issue because i have a standard? does it matter that i hae a standard? and also, would they be able to set it up so my doors unlock when i turn the car off? keep in mind the car is still running when my key is out of the ignition.. and also, how about removing the headlight flashes when i lock/unlock, remote start my car? i have hids and supposedly its not good for the bulbs to be going on and off like that.. thanks for the help
Assuming they're using a BladeAL Bypass module (Compustar has a slot on the brain for them to slide into) there will be a RAP wire that needs to be wired into the drivers side door at the BCM. I believe its Orange/Black.
