UPDATED General Stereo FAQ - READ THIS!
Old 06-27-2010 | 11:21 PM
  #251
EmperorJJ1's Avatar
the lan 04 will work for a 09 pionner system with onstar and xm
Old 07-29-2010 | 12:52 PM
  #252
corey_osu10's Avatar
ok so i got a sony headunit, got it all wired, and inititally i had no sound at all, tiul i read your post about taking the amp wire into the pink harness wire, that fixed it. so now i have sound and all my sources work, except my radio. its all static, even hometown stations. complete static. cd works, ipod works, but no radio..any ideas?
Old 07-29-2010 | 12:55 PM
  #253
EmperorJJ1's Avatar
if your antenna is plugged in to the car and you bought the antenna adapter and that is plugged into the radio... i would check to see if anything came loose in the back of the car. if not id check to see if the antenna adapter is broken (if your car is a 07+).... the chrysler antenna adapters have that lil pin in the middle and they break pretty easily
Old 07-29-2010 | 01:01 PM
  #254
i do have the antenna adapter and its hooked up.. its an extension from the stock antenna wire then it plugs into a wire from my hu.
Old 07-29-2010 | 01:31 PM
  #255
EmperorJJ1's Avatar
right right and the car is what an 05?
Old 07-29-2010 | 03:01 PM
  #256
yessir.
Old 07-31-2010 | 04:09 AM
  #257
EmperorJJ1's Avatar
try peeling back the carpet in the back and double checking the antenna is still plugged in.
Old 07-31-2010 | 02:21 PM
  #258
alright man ill take a look thanks
Old 08-13-2010 | 10:52 PM
  #259
CrateEngineDepot's Avatar
EmperorJJ1, awesome thread. heres my question.
I have a 2010 with US8 radio, onstar, and nav.
I want to add Bluetooh for my cell, have you any experience with this yet?
Old 09-11-2010 | 06:15 PM
  #260
Rydis's Avatar
how do you hook up the radio using the Gmos-04? The output side of the harness only has 1 wire for each speaker..but radio harness still requires 2 for each wire...?? Its an avic d-3
Old 09-12-2010 | 01:22 AM
  #261
EmperorJJ1's Avatar
no unfortunately i dont. a few companies make modules to add the bluetooth but i have no idea the quality or whats involved
Old 09-12-2010 | 01:25 AM
  #262
EmperorJJ1's Avatar
well you shouldnt be using that harness at all. but it should have 2 per speaker. the gm-lan-04 will only have rca outputs for the pioneer system.
Old 09-13-2010 | 09:59 AM
  #263
Curleh_Mustachio's Avatar
Hi, totally new here. Um, I've been having a hard time trying to find out if a new, aftermarket head unit would work with a factory XM satellite module?
Old 09-13-2010 | 05:23 PM
  #264
EmperorJJ1's Avatar
no. the only thing you "might" be able to reuse would be the antenna. You would need to buy the aftermarket XM modules
Old 09-14-2010 | 10:25 PM
  #265
I figured as much. I was trying to find a tuner for the Sony cdx-gt540ui (which is apparently not compatible with the XMDSON100 and Universal Tuner), but the only one I found was the xm-xt1, which is not sold anywhere.
Old 09-15-2010 | 05:02 AM
  #266
EmperorJJ1's Avatar
hmm quick google search looks like it uses the same ****. diff part numbers but
XMDirect2 Sony Car Kit Add XM Satellite Radio to your Sony receiver at Crutchfield.com
Old 09-19-2010 | 07:30 PM
  #267
Rydis's Avatar
yep your right
one last question though. What causes the loud "thump" or "thud" sound when the car is turned off and the radio with it.
Old 09-19-2010 | 10:03 PM
  #268
EmperorJJ1's Avatar
that is normally the radio turning off before the car. the remote for the factory amp and or remote for any aftermarket amp should be hooked up to the remote from the radio
Old 09-20-2010 | 03:39 PM
  #269
Rydis's Avatar
yeah thats what I thought...however..say your radio didn't have a remote/amp turn on wire. My Gmos harness has the amp turn on wire..but my radio doesn't. My radio has a Power Antenna Wire..but the Gmos doesn' thave a Power Antenna Wire. Right now the Amp Turn on Wire is connected to the Power Antenna wire.
Is there another wire I can change to where it doesn't do this and powers down correctly?
Old 09-20-2010 | 08:16 PM
  #270
EmperorJJ1's Avatar
not really. the power antenna should work even thou its not a true remote out. The only option other then replacing the radio would be to buy ground loop isolators for the rcas and hope that helps. but thats really a shot in the dark
Old 09-22-2010 | 09:16 AM
  #271
OK, so I finally got around to purchasing the correct XM tuner and also a new cd deck (Sony CDX-GT540UI). I soldered the wires of the cd harness to a Metra 70-2103 harness and bought the necessary stuff (dash kit, antenna adapter...). But when I plugged it in, nothing happened. The faceplate didn't light up or anything. The rest of the car ('06 Cobalt LS) worked perfectly normal, just not the radio. When I checked the layout of the factory harness, it was not only different in color, but one of the pins didn't match up with the Metra harness. Any suggestions?
Old 09-22-2010 | 10:34 PM
  #272
blackbalt sport's Avatar
Quick question. Installing aftermarket HU in 06 ss/sc with pioneer system. have the axxess interface XSVI2103 harness and can't get the deck to light up. The cd player buzzes as if it has power but nothin happens. Any quick ideas?
Old 09-23-2010 | 03:13 AM
  #273
EmperorJJ1's Avatar
where is the red acc connected to?
Old 09-23-2010 | 03:15 AM
  #274
EmperorJJ1's Avatar
hard to tell on a module harness like that. id say test the acc and constant and see if both are getting voltage. in most cases a cd player will make that noise when first connected to constant, so if u keep hearing it thats defiantly weird
Old 09-23-2010 | 04:43 AM
  #275
I had it connected to a wiper fuse (fuse #15) in the floor panel, 10 A I believe. I checked the stock harness and there's a green wire that when attached to the metra 70-2103 harness, is actually not connected to anything in the harness. But neither is the blue antenna wire from the metra harness. Both wires are in a different pin space.
Quick Reply: UPDATED General Stereo FAQ - READ THIS!
