UPDATED General Stereo FAQ - READ THIS!
#176
Thanks again for the help,
I purchased an aftermarket HU, The harness has 8 speaker wires, then:
yellow - battery lead
red - acc power
black - ground
orange- unknown/not used
orange/white - unknown/not used
blue - unknown/not used
other than the unused wires, using the Metra 70-2103 will more or less match wires correct?
How do I pull power, by running the yellow wire to a power source?
red - acc power
black - ground
#177
orange & orange white just cap off so they dont touch anything. If you have the pioneer system then you will need to hook up blue to the 70-2103 to turn on the stock amp. If not then cap it off so its not touching anything
ACC or red is the one not in the car. you will need to run the supplied wire to the fusebox with an add a fuse or fusetap
#180
hey guys i got a question i cant find the cheap harness for my 07 with the xm and 6 cd changer one can someone send me a link? the only thing i will lose by using a cheap one is my door ding and signal sounds?
#181
right the only thing u loose going from the 2 harnesses is the door chimes. you also loos steering wheel controls and xm going aftermarket
http://shop.ebay.com/i.html?_nkw=met...2104&_osacat=0
#182
#184
I have a 08 ls without pioneer and onstar. I got the 70-2202 and of course a aftermarket hu. Out of the hu is yellow, black, red, orange/white, blue/white, grey, grey/black, white, white/black, purple, purple/black, and green, green/black. I hooked them to the same color on the metra 70-2202 and plug the metra to the factory harness. I still have a orange only wire left from the metra. When I turn on the car nothing happens. What's wrong?!?!?
Anyone know?
Anyone know?
#188
k thanks man
anyone know how to remove stock sub? i got box and everything out but the sub wont come out is there a trick?
Last edited by stoon_cobalt_colby; 01-25-2010 at 03:47 PM. Reason: Automerged Doublepost
#191
sooo, any ideas on how to make a cd player fit? mine sticks out a bit, its that damn bracket in the back thats stopping it. Is it safe to dremel that, it seems like the heating/ac ducting runs behind it. any input or how to on this would be great!
#193
Secondly I'm confused with these two wires below. Where do I connect them? My hu doesn't have these color wires, unless their different color wires on the hu.
"2. Connect the blue/pink wire to the VSS or speed sense wire of the aftermarket navigation radio."
"3. Connect the green/purple wire to the reverse wire of the aftermarket navigation radio"
And lastly, I don't get what they mean with the black/yellow wire. Do I just connect it to the ground wire? What do they mean about tapping?
#195
Ive looked through several pages.. The sites so slow its finally killed me.. I have the 06 SS/SC without onstar.. pioneer sound system blah blah lol. I need to know the minimum I have to buy to get an aftermarket deck to work. Local shops, crutchfield and best buy tell me I need a harness thats 170 dollars(90 from crutchfield) to get it to work. I look at the harness on crutchfield and the harness has the DIC underneath the stereo... I dont need that do i? my DIC is underneath the tach. Cant I save myself the hassle and just get:
http://www.crutchfield.com/p_1272RGM...n-Adapter.html
(60 dollars through crutchfield)
and the deck and thats it? well it comes with:
http://www.crutchfield.com/p_142GM15...eiver-Kit.html of course so you know what I mean.
#197
#199
hey guess i recently hooked up a electric cross over to run amps and speakers just wondering why when i hook up my rear speakers to the crossover it makes a loud buzzz noise
