Upshift light? help please
apperently we have one... but i think we came to the conclusion its set to turn on at RPM's above stock redline/limiter cause some people can get it who have raised thier rev limiter and redline that.
And noone can figure out how to tune it so it works... not all that nessisary anyhow
i think the shift light works pretty well, it sets itself at different points depending how you drive, if you are just driving normal it tells you to shift at about 3-3.5k and if you are flooring it, it will tell you to shift at 5.5-6k, this is pretty awesome considering a shift light that just does one RPM costs around 150 bucks. I am actually "moving" my shift light to a more visible location on top the dash, mainly it will be helpful for Autocrossing, or any other racing event, when its easy to forget to shift.
why do u have 2 posts? it does have a upshift but for the ss/sc its to tell you when your engine will blow basicly. most people will never see it. if you want better gasmilage in the city, turn off the boost in 1st gear til 4000 rpm, you can also turn it off in 2nd also... that means you would be a N/A 2.0 til 3rd.
i did it in 1st and my gas for city went up about 3-5mpg, if you did it in second also it would make a huge difference
https://www.cobaltss.net/forums/pictures-videos-64/lsj-shift-light-cought-tape-82164/ <---yes..the SS does have a shift light and it does come on
z28addiction
09-28-2015 12:03 AM
