Wanting to door swap for power windows
Old 03-04-2017 | 10:00 PM
intel's Avatar
Got a question...
Have a Cobalt LS coupe with crank windows. I got two complete doors for about $120. When I say complete I mean the whole entire door, all I did was remove the door from the hinges to pull it from the donor car. These doors are powered and I only really care about the powered windows, don't care about powered locks.
I am planning on swapping the doors so that I can get power windows. How would I go about wiring it? I took a look at the how-to and I am not really following it. I would have figured I could tap that green wire to the switch and I would be good, but that does not seem to be working.
Can include pictures if needed.
Thanks in advance.
Old 03-04-2017 | 11:59 PM
intel's Avatar
Made some progress by finding this thread... https://www.cobaltss.net/forums/gene...agrams-107288/
Driver side worked, thinking passenger side switch might be dead
Tell me if this looks right
Driver side window switch:
Green wire has 12v switched source (Letter C)
Black wire I grounded (Letter F)
What wire/letter do I need to run from driver side to passenger side to control passenger side window?
Passenger side window switch
Green wire has 12v switched source (Letter A)
Black wire I grounded (Letter C)
Old 03-06-2017 | 11:56 AM
EmperorJJ1's Avatar
to be honest i have no idea. my non audio electrical wiring abilities are basiclly gone. back in the day i would test things just because i was curious but now no garage so cant do much. Sorry man wish i had a better answer for you.
Old 03-07-2017 | 01:53 AM
Im surprised you got as far as you did with that thread. No diagrams! Lol. Hold on
Old 03-07-2017 | 02:08 AM
Fail on my part, theres no diagram but it looks like theres two signal wires that run between the switches to control the passenger window.
Old 03-08-2017 | 09:02 PM
EmperorJJ1's Avatar
slowbalt you are a genious. Also one of the screenshots i had is corrupt so only one power window
Attached Thumbnails door-lock-indicator.gif   door-lock-indicator.gif   power-window-1.gif   system-diagram.gif   system-diagram-2.gif
Old 03-09-2017 | 08:08 PM
LsCobalt07's Avatar
Not sure if this helps
Drivers Window Switch
Pin Wire Color Circuit No. Function
A L-BU 166 Power Window Master Switch Right Front Up Signal
B GY 8 Instrument Panel Lamp Supply Voltage
C D-GN 801 Retained Accessory Power Fuse Supply Voltage
D TN 167 Power Window Master Switch Right Front Down Signal
E -- -- Not Used
F BK 650 Ground
G D-BU 164 Power Window Motor Left Front Up Control
H BN 165 Power Window Motor Left Front Down Control
passengers window switch
A D-GN 801 Retained Accessory Power Fuse Supply Voltage
C BK 650 Ground
E -- -- Not Used
Old 03-09-2017 | 11:53 PM
alchargo's Avatar
Here's some more info I pulled off Alldata that may help.
Attached Thumbnails window-switch-front-passenger-a31-.gif   window-switch-front-passenger-a31-info.gif   window-switch-driver-coupe-a31-.gif   window-switch-driver-coupe-a31-info.gif   window-motor-front-coupe-a31-.gif
window-motor-front-coupe-a31-info.gif   136985528.gif   136985520.gif   136850206.gif   136850200.gif
Old 03-10-2017 | 11:30 AM
LsCobalt07's Avatar
Here's what to connect where. Lots of time was invested in this high quality wiring diagram
Old 03-10-2017 | 12:36 PM
^^^ this guys a baller
