What adapters to get?
I'm going to have two cobalts in the house and there both getting aftermarket radios, but I want them to fit in like they were stock, so her in lies the questions....
05 cobalt LS with base radio, what do I need to keep the RAP and the steering wheel controls? Anyone have a color number for the Satin Nickel (to paint the dash kit) or should I just take it to the paint store?
Am I missing anything? Wire harness numbers and dash kit numbers maybe?
And the Same thing for my 06 SS/SC (with onstar and XM), what adapters do I need?
I'm starting with the G/f's 05 so mostly I need to know the steering wheel controls and the RAP. Her radio is a Clarion DXZ955MC
Thanks for any help.
Even if it's a Pain, I still want to keep everything....Will the regular wireing harness keep the Chimes and RAP thingy?
Why not use the same +12V wire for the new deck, that was used for your stock one? Then you can keep RAP. And if that wire is not capable of delivering the 5A or whatever is needed for your deck (I dont know if it is) then simply find a 12V source that IS capable of running your deck and use the 12V RAP line as a relay trigger for the other 12V source.
Originally Posted by italstalnprd86
Im pretty sure i ran a seperate power wire right to the deck
Originally Posted by crazydemon
I mean, if there is no 12V at the harness, then how does the stock deck get power? There's got to be one there.
Ahh, that makes sense.
Sorry if I confused anyone then. What you can do in that case is still go with the relay option, but pull a switched wire from elsewhere. As was mentioned, the sunroof probably has a swiched 12V, or the power windows.
Electrical: How-To: Oil Pressure Install on 2006 Cobalt LS
Blackout06LS
How to Guide
38
05-13-2008 09:42 AM
