What Amp For Two 12" type R Alpine Subs??
Old 02-08-2009, 01:52 AM
09BlackLT's Avatar
Hey guys I just got two Alpine type R 12" subs today. What amp and wattage should I be looking for to power these?? Hope I can get some ideas! Thanks
Old 02-08-2009, 02:05 AM
nikebaseballx00's Avatar
depends on the subwoofer, is it dual 2 ohm or dual 4 ohm
u would need something with 1000watt rms
Old 02-08-2009, 02:07 AM
copson20's Avatar
like this amp https://www.cobaltss.net/forums/stuff-137/fs-audiobahn-amp-a12001dt-130186/
Old 02-08-2009, 02:08 AM
drop-n-destroy's Avatar
You need at least a 1000W amp. I has one for sale!! Perfect for our set up. Look>>https://www.cobaltss.net/forums/stuff-137/fs-alpine-1000w-car-amplifier-mrd-m1005-134851/
Old 02-08-2009, 02:14 AM
stinkyfisherman's Avatar
how much are you looking at spending on the amp?
Old 02-08-2009, 02:30 AM
09BlackLT's Avatar
It's the dual 2 ohm. I guess I would spend up to $500 to $600, not quite sure yet. What you guys think?
Old 02-08-2009, 02:35 AM
get a mono that puts out 1000watts rms at 2ohms
or get a 2 channel that puts out 500watts x 2 channels at 4ohms
mono would be best bet
Old 02-08-2009, 02:41 AM
09BlackLT's Avatar
Would 4 gauge wire be heavy enough?
Old 02-08-2009, 09:51 AM
cmiller8006's Avatar
I have two jl audio 500/1 amps 500 rms from 1-4 ohms, I would sell them both for 500.00 obo there in really good shape like brand new. it is the two black amps that say jl on them
Old 02-08-2009, 10:06 AM
4 gague should be fine. Look into rockford fosgate, cadence, jbl, hifonics, soundstream, jl, and memphis just to name a few that are good amps for a good price.
Old 02-08-2009, 10:29 AM
09BlackLT's Avatar
Would the Alpine M1000 be a good amp to power these? Also should I use a cap too?
Old 02-08-2009, 12:40 PM
The Alpine M1000 it is perfect to run the RMS wattage on your subs, if you want to go peak then you should get more than 1000W which I don't think you won't need to go that far. My amp will be perfect. I was running one 12" Alpine type-X at 1000W at 2ohms and it was more than enough to power that baby. Also, with the M1000 you can control it from the head unit IF you have an Alpine HU. PM if you're interested on my amp
Old 02-08-2009, 03:44 PM
Spun's Avatar
You have 2 DVC 2 ohm subs
This would put your final draw at 0.5 ohms or 0.25 ohms either way there are not many amps out there today that can do this (I long for the cheater amps of the past)
So in order to run it off a mono amp you'll have to run it in series (unless you can find a 2 channel amp thats good to 1 ohm stereo, good luck)
In order to get the power you need you will have to find a mono amp that runs 1000 watts @ 4ohms because this will be the final output with a set up run in series.
So remember alot of amps rate their power at 2 ohms, if the amp says 1000 watts at 2 ohm them it might only be 500 at 4 ohms
Make sure that your amp puts out 1000 watts at 4 ohms and you'll be just fine
Old 02-08-2009, 06:26 PM
^^^^uh... 2 dvc 2ohm subs you can run them at 2 ohms.
Wire each sub in parallel and then both subs in series to the amp... 2 ohms.
Or each sub in series then both subs to the amp in parallel... 2 ohms.
The alpine m1000 is rated at 1000w 2ohms that will be a good amp for those R's.
If you have the manual for the type R's look it up its on there. Page 3, example 4. I found the manual on alpines website.
Old 02-08-2009, 06:30 PM
loco-performance's Avatar
look in my sig. hit 146.8 lol was looking for this Alpine MRD-M1005. thats alll u need unless u wanna go def
Old 02-08-2009, 06:44 PM
Spun's Avatar
Your right I don't know what I was thinking, 2 ohms is out put if you run them in series and then parallel back to the amp,
I had 4 stuck in my head for some reason, oh well it was to early to be doing math anyway
In that case that M1000 (depending on how much $$$ he wants for it) would run the subs
Old 02-08-2009, 06:46 PM
myfakeevo's Avatar
i have two alpine type r12s, get an amp that has a 300watts continuous output max or your going to blow them up. cause i have haha.
Old 02-08-2009, 06:54 PM
its all good man...
The amp runs about 300 new (woofers) so its kinda pricy.
I was pushing mine (when I had them) with a fosgate 1000.1 and was giving them close to 600 rms each, they worked fine. Ive even seen someone give them 1000w each and they pounded for quite a long time I think he got a year and a half out of them.
Last edited by stinkyfisherman; 02-08-2009 at 06:54 PM. Reason: Automerged Doublepost
Old 02-08-2009, 06:58 PM
09BlackLT's Avatar
Thanks guys, should I be using a capacitor also?
Old 02-08-2009, 07:06 PM
I dont think they are any use whatsoever. IMO they just put more of a strain on the electrical system. Get a better battery than factory and if you feel up to it do the big 3 upgrade
Old 02-08-2009, 07:48 PM
when i got my cap installed my lights stopped flickering and sounded a bit more better
Old 02-08-2009, 08:01 PM
I just believe its better to do proper wiring and charging system. Try it out and if you don’t like it pull it out.
Old 02-08-2009, 08:40 PM
Spun's Avatar
A cap only works if you have the current there to start with, if your drawing more power than your car can dput out then a cap is not only not going to help you but in the end put more of a strain on the electrical system.
At 2300 watts my system draws over twice what the alt can put out but no cap is going to help that, not even a Kinetik HC 1800 totally stoped the light dim, I have 2 of the big 3 done but have a feeling the 3rd isn't going to stop it either so I am having an alt built from the ground up by a local guy, its costly but the only way to get a 200+ amp alt for these cars, short of a problematic 2 alt setup.
If your drawing less than 105 amps then a cap might help, but IMO there just a plecebo, they make you think there working but really there just for show
Old 02-08-2009, 11:07 PM
The same way I see it.
Old 02-08-2009, 11:47 PM
09BlackLT's Avatar
Ok thanks guys! I won't put that on my list now! hehe
Quick Reply: What Amp For Two 12" type R Alpine Subs??
